Anyconnect 2.5.3051 Mac OS X 10.6.8 issue
Aug 5th, 2011
Hello Everyone,
I have a problem with connection to ASA via anyconnect after upgrade (annyconnect).
When I trying to connect to ASA see as below:
[08/05/11 12:37] Checking for customization updates...
[08/05/11 12:37] State:: Connecting
[08/05/11 12:37] Checking for localization updates...
[08/05/11 12:37] Establishing VPN session...
[08/05/11 12:37] Establishing VPN - Initiating connection...
[08/05/11 12:37] State:: Connected
[08/05/11 12:37] Establishing VPN - Examining system...
[08/05/11 12:37] Establishing VPN - Activating VPN adapter...
[08/05/11 12:37] Establishing VPN - Configuring system...
[08/05/11 12:37] Establishing VPN...
[08/05/11 12:37] VPN session established to xxx.xxxxnet.pl.
[08/05/11 12:38] State:: Reconnecting
[08/05/11 12:38] Reestablishing VPN session to xxx.xxxnet.pl...
Do You have some troubles with thees software version as above?
Regards.
Karol
k.goralski Fri, 08/05/2011 - 07:18
I found in my logs such entries..
Code: -31522780 (0xFE1F0024) Description: SOCKETTRANSPORT_ERROR_CONNECT_TIMEOUT
Aug  5 16:06:46 gooroos vpnagent[19904]: Function: OnTransportInitiateComplete File: TlsProtocol.cpp Line: 481 Invoked Function: CSocketTransport::initiateTransport Return Code: -31522780 (0xFE1F0024) Description: SOCKETTRANSPORT_ERROR_CONNECT_TIMEOUT
Aug  5 16:06:46 gooroos vpnagent[19904]: Function: OnTunnelInitiateComplete File: CstpProtocol.cpp Line: 1007 Invoked Function: initiateTunnel Return Code: -31522780 (0xFE1F0024) Description: SOCKETTRANSPORT_ERROR_CONNECT_TIMEOUT
Somebody know what this "Code: -31522780" mean?
Thanks for Your help
Atri Basu Sun, 12/02/2012 - 13:55
  • Cisco Employee,
Karol, it's unlikely you'll be provided with the meaning of that code id, at least not on an open forum. If you are having trouble connecting with the client i would recommend opening a case with TAC to troubleshoot this.
Related Content
