Problem with GRE over IPsec with IOS Version 15.1(2)T4
Answered Question
Aug 5th, 2011
HI there,
we have multiple sites using GRE Tunnels with crypto map for encryption.  On upgrading a UC-520 to the latest version (15.1(2)T4 or any version of this train) I get the following error:-
SIN-UC520(config-if)#crypto map aberdeen
% NOTE: crypto map is configured on tunnel interface.
        Currently only GDOI crypto map is supported on tunnel interface.
The original Tunnel config is below:-
interface Tunnel0
description Tunnel To Aberdeen HQ
bandwidth 512
ip unnumbered Vlan1
ip mtu 1420
qos pre-classify
tunnel source a.b.c.d
tunnel destination e.f.g.h
crypto map aberdeen
Downgrading the IOS to an earlier version fixes the problem.   What gives?  Have Cisco dropped support for this configuration?
I use this configuration so I can select exactly which traffic is to be encrypted (I do not encrypt voice for example).
Peter.
Correct Answer by raga.fusionet about 5 years 8 months ago
Hi Peter,
It looks like starting on 15.1 that configuration is no longer supported. Here's what the release notes say:
Error message is displayed when you try applying the tunnel interface to a crypto map.
Old Behavior: Error message is not displayed when you try applying the tunnel interface to a crypto map using the crypto map (interface IPSec) command.
New Behavior: An error message is displayed when you try applying the tunnel interface to a crypto map using the
http://www.cisco.com/en/US/docs/ios/15_1/release/notes/151TNEWF.html
The command reference has the following info about the error message:
A crypto map cannot be applied to a tunnel interface. If you try to apply the tunnel interface to a crypto map, an error message is displayed as follows:  crypto map is configured on tunnel interface. Currently only Group  Domain of Interpretation (GDOI) crypto map is supported on tunnel  interface.
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_c4.html#wp1078283
So it looks like on the new version you can only use a GDOI crypto maps (completely new to me) on your tunnel interfaces.
Here is a doc that explains the implementation of GDOI, I wish I could help with the configuration but like I said, I hadnt heard of it until today.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6660/ps6811/prod_white_paper0900aecd804c363f.html
I hope this clarifies your questions.
Raga
Overall Rating: 4.3 (3 ratings)
Correct Answer
raga.fusionet Fri, 08/05/2011 - 09:51
  • Silver, 250 points or more
Hi Peter,
Raga
Leo Laohoo Sun, 08/07/2011 - 16:48
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
I'd be looking at your IOS.  If the IOS filename has a "k" then crypto is supported.
alexheng81 Sun, 08/07/2011 - 18:15
But the previous IOS we are using is 150-1.XA3a ... and we don't seem to any issues ....
Leo Laohoo Sun, 08/07/2011 - 18:19
  • Hall of Fame,
    2017 LAN, Wireless
Hi Alex,
Can you post the complete filename of the old and new IOS please?
raga.fusionet Sun, 08/07/2011 - 18:23
Alex, Peter,
These changes were introduced on 15.1(1)T.  A "T" train comes after the general release, so you are uprading to a version that no longer supports crypto maps on tunnel interfaces unless they are GDOI.
Here is the release notes again:
Just search for crypto map and you will see it.
alexheng81 Sun, 08/07/2011 - 18:25
Hi leolaohoo,
old version, uc500-advipservicesK9-mz.150-1.XA3a
new version, uc500-advipservicesK9-mz.151-2.T4
raga.fusionet Sun, 08/07/2011 - 18:28
Also, from the command ref:
Note A crypto map cannot be applied to a tunnel interface. If you try to apply the tunnel interface to a crypto map, an error message is displayed as follows:  crypto map is configured on tunnel interface. Currently only Group  Domain of Interpretation (GDOI) crypto map is supported on tunnel  interface.
pierrescotland Mon, 08/08/2011 - 06:19
Thanks for the reply Luis,
I will have to review the docs and come up with a migration strategy.   It seems a bit strange to remove this feature, I can't be the only one using it!
cheers
raga.fusionet Mon, 08/08/2011 - 08:27
Peter, I agree with you, it's really weird, and I've seen other people doing it.  So I have no idea of why Cisco did it.
I hope you can come up with a solution.
Have fun.
PS: Please remember to mark this question as answered and rate this post if helpful. Thanks!
