I need to all icmp through the ACE to servers behind the ACE
Aug 5th, 2011
I have been trying to figure this out and I've made several attempts at a configuration that will work, but I just don't get it.  Here's what I have configured.  I'm trying to ping from a server outside of the ACE to a server on vlan 308.  I send my ICMP it should ingress through vlan 302 and hit the server on vlan 308.  Instead I get nothing and I see no traffic hits on my policy or from the show icmp statistics.  I am able to ping the IP addresses on vlan 302 but nothing on the inside.
access-list icmp line 10 extended permit icmp any any
class-map match-all icmp-allow-inspect
  2 match access-list icmp
policy-map multi-match icmp-allow-inspect-mmpl
  class icmp-allow-inspect
    inspect icmp error
interface vlan 302 --------- public facing VIPs- ingress
  ip address 71.113.93.37 255.255.255.224
  alias 71.113.93.36 255.255.255.224
  peer ip address 71.113.93.38 255.255.255.224
  service-policy input mgmt
  service-policy input icmp-allow-inspect-mmpl
  no shutdown
interface vlan 308 ---------- server - L2
  ip address 10.60.22.130 255.255.255.192
  alias 10.60.22.129 255.255.255.192
  peer ip address 10.60.22.131 255.255.255.192
  no shutdown
jsirstin Fri, 08/05/2011 - 12:31
  • Cisco Employee,
If this ICMP traffic is just being routed by the ACE could you try appling an access-list to each interface that allows ICMP
traffic?
Sample:
access-list anyone extended permit ip any any
Interface vlan 308
access-group input anyone
interface vlan 302
Jim
shday Fri, 08/05/2011 - 12:34
I tried that already, that was my original configuration
jsirstin Fri, 08/05/2011 - 12:45
  • Cisco Employee,
I have a few additional questions.
Do you have a layer 3 interface other than the ACE on vlan 302?
If you do not have any other layer 3 interface do you have a route pointing to the ACE on vlan 308 as the next hop to get to the server?
What gateway does the server you are trying to ping on vlan 302 use?
Jim
shday Fri, 08/05/2011 - 12:50
question 1 - not from the outside.  All other vlans are layer 2
question 2 - I do have a route on my upstream router to vlan 308 via the alias address on vlan 302.
question 3 - the gateway on all the servers on vlan 302 is the alias address.
I also tried to ping the ip address on int vlan 308 and I can't ping that either.
jsirstin Sun, 08/07/2011 - 04:52
  • Cisco Employee,
If you have the proper routing to get traffic to the client side of the ACE, and the servers use the server vlan as the default gateway all you should need is the following to allow a ping to route through the ACE.
An ACL allowing traffic into the interfaces, and a default route so the ACE knows how to forward the reply traffic back to the client.
If you have the ACL applied and a default gateway can you get a sniff to confirm that the pings are arriving at the ACE alias?
Thank you
Jim
shday Sun, 08/07/2011 - 21:10
I ran a capture and I see the traffic hit the ingress interface of the ACE, but it never gets passed to the backend server vlan.  The icmp is recieved and the connection is closed, but then I get 4 more packets marked PKT_XMT then the packet is dropped.  The capture was done on the ingress vlan.  If I do a capture on the server side vlan I get nothng at all in the capture.
0001: msg_type: PKT_RCV
ace_id: 6809            action_flag: 0x13
src_addr: 74.113.193.34            src_port: 53575
dst_addr: 10.62.222.136            dst_port: 2048
l3_protocol: 0          l4_protocol: 1
0002: msg_type: CON_CLOSE
con_id: 1345505684       out_con_id: 271763861
0003: msg_type: PKT_XMT
con_id: 1345505684              other_con_id: 0
0011: msg_type: PKT_XMT
0019: msg_type: PKT_XMT
0029: msg_type: PKT_XMT
0037: msg_type: PKT_DROP
con_id: 1345505684           reason: 0
This is my access list and its applied globally with the access-group input ALL command.  I also have my default gateway pointing back to my upstream router and there are no other routes on the ACE.  I can ping the ingress interface from my upstream router and I can ping my gateway from the ACE.  I can ping my backend server from the ACE, but not from anything outside the ACE.  I can not ping anything behind my ACE module.
access-list ALL line 12 extended permit icmp any any
access-list ALL line 18 extended permit ip any any
jsirstin Mon, 08/08/2011 - 06:18
  • Cisco Employee,
Sharon,
I see you opened a TAC case on this issue. I am looking at the capture icmp.pcap. Can you confirm who owns the mac address 00.0b.fc.fe.1b.14 and 00.24.e8.5f.9a.20 and what were you spanning when you took the capture? If it is the ACE that owns the mac 00.0b.fc.fe.1b.14 then it looks like the packets are being passed through and I would suggest setting up a capture directly on the server interface to verify if it is receiving them.
Thank you
Jim
