Warning message
Mixing Catalyst switches in the same stack
Aug 8th, 2011
Is it possible to have a WS-C3750G-12S-S and a WS-C3750X-24T-L in the same stack, if so do they need to both be running the same software version/IOS.
Thanks in advance.
Gavin
Leo Laohoo Mon, 08/08/2011 - 16:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
If you have a 3750X-24T, your entire stack should be running a minimum of 12.2(53)SE1.  Anything less and the 3750X will not join the stack and the stack won't even know what a "3750X" is.
Somasundaram Ja... Mon, 08/08/2011 - 21:41
  • Cisco Employee,
Yes it is possible to have both these switches in stack. One more important thing to note is that the license should be same on both the switches.
3750x switch supports three software feature sets: Lanbase, ipservers, ipbase
Show license detail output from each switch will tell you with what license exactly the switch is running.
Hope this helps
Cheers
Somu
Rate this answer if you find the content was useful.
chrisvanwyk Mon, 04/16/2012 - 01:23
I Managed to stack 3570 X with 3750 G this weekend.
3750 X running IOS
C3750E-UNIVERSALK9-M
3750G running IOS
C3750-IPSERVICESK9-M
Switch Ports Model              SW Version            SW Image
     1 18    WS-C3750X-12S      12.2(58)SE2           C3750E-UNIVERSALK9-M
     2 18    WS-C3750X-12S      12.2(58)SE2           C3750E-UNIVERSALK9-M
*    3 52    WS-C3750G-48TS     12.2(58)SE2           C3750-IPSERVICESK9-M
     4 52    WS-C3750G-48TS     12.2(58)SE2           C3750-IPSERVICESK9-M
Seems all you need is the SW version to match.
Chris
hobbe Mon, 04/16/2012 - 03:05
  • Gold, 750 points or more
No this will not work
The Lan base will only stack with other Lan base switches.
You can not mix lan base and ipbase/ip services
it does not matter if the software is the same version or not.
They will not stack with eachother.
IF you update the Lan base license key to an ip base then it will stack with your switch if they have the same software version.
Good luck
chrisvanwyk Mon, 04/16/2012 - 03:16
Sorry what I meant so say if the software and feature set match it will work.
Related Content
