WAAS 4.41 upgrade & WCCP
Aug 8th, 2011
Since upgrdae a 512 WAAS to 4.4.1 which connects to a 3750, WCCP will not associate.
A debug on the 3750 "deb ip wccp eve" gives the following :
Aug  8 15:16:35: WCCP-EVNT:D61: Here_I_Am packet from 172.18.4.241 w/bad rcv_id 00000000
Aug  8 15:16:36: WCCP-EVNT:D62: Here_I_Am packet from 172.18.4.241 w/bad rcv_id 00000000
comming from the waas
2011 Aug  8 14:36:10 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Query removal message from 172.18.4.242
2011 Aug  8 14:36:10 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: wccp2.c:8176:
2011 Aug  8 14:36:10 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Removal Query from rtr 172.18.1.1 which is not configured for service 61.
2011 Aug  8 14:36:27 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: wccp2.c:8156:
2011 Aug  8 14:36:27 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Query removal message from 172.18.4.242
2011 Aug  8 14:36:27 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: wccp2.c:8176:
2011 Aug  8 14:36:27 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Removal Query from rtr 172.18.1.1 which is not configured for service 62.
2011 Aug  8 14:36:40 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: wccp2.c:8156:
2011 Aug  8 14:36:40 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Query removal message from 172.18.4.242
2011 Aug  8 14:36:40 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: wccp2.c:8176:
2011 Aug  8 14:36:40 UKHSL-WAAS02 wccp: %WAAS-UNKNOWN-7-899999: Removal Query from rtr 172.18.1.1 which is not configured for service 61.
where as the switch is send
HSL-S-001#
Aug  8 15:37:38: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B16
Aug  8 15:37:39: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B1E
HSL-S-001#
Aug  8 15:37:40: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B17
HSL-S-001#
Aug  8 15:37:41: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B1F
Aug  8 15:37:42: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B18
HSL-S-001#
Aug  8 15:37:43: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B20
Aug  8 15:37:44: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B19
Aug  8 15:37:44: WCCP-PKT:D61: Sending Removal_Query packet to 172.18.4.241w/ rcv_id 00018B21
HSL-S-001#
Aug  8 15:37:45: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B22
Aug  8 15:37:46: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B1A
HSL-S-001#
Aug  8 15:37:47: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B23
HSL-S-001#
Aug  8 15:37:48: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B1B
Aug  8 15:37:49: WCCP-PKT:D61: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B24
HSL-S-001#u all
All possible debugging has been turned off
HSL-S-001#
Aug  8 15:37:50: WCCP-PKT:D62: Sending I_See_You packet to 172.18.4.241 w/ rcv_id 00018B1C
WCCP Status switch
HSL-S-001#sh ip wccp 61
Global WCCP information:
    Router information:
        Router Identifier:                   172.18.1.1
        Protocol Version:                    2.0
    Service Identifier: 61
        Number of Service Group Clients:     0
        Number of Service Group Routers:     0
        Total Packets s/w Redirected:        0
          Process:                           0
          CEF:                               0
        Redirect access-list:                WAAS-IP
        Total Packets Denied Redirect:       0
        Total Packets Unassigned:            0
        Group access-list:                   -none-
        Total Messages Denied to Group:      0
        Total Authentication failures:       0
        Total Bypassed Packets Received:     0
WCCP Status WAAS
KHSL-WAAS02#sh wccp routers
Router Information for Service: TCP Promiscuous 61
        Routers Seeing this Wide Area Engine(0)
                -NONE-
        Routers not Seeing this Wide Area Engine
                172.18.1.1
        Routers Notified of from other WAE's
                -NONE-
        Multicast Addresses Configured
                -NONE-
Router Information for Service: TCP Promiscuous 62
                -NONE-
                172.18.1.1
                -NONE-
                -NONE-
Any ideas
Overall Rating: 5 (1 ratings)
Michael Korenbaum Mon, 08/08/2011 - 08:09
Ian,
Can you provide the show run output from both the WAE and the 3750?
Also give the output of show sdm prefer and show version from the 3750.
Have you tried bouncing WCCP (on the WAE no wccp ver 2, wccp ver 2)?
Note when doing wccp with WAE and 3750 these are the requirements/ restrictions:
1) WAE must be Layer 2 adjacent and configured for l2-redirect and mask-assignment
wccp tcp-promiscuous router-list-num 8 l2-redirect mask-assign
2) The 3750 must be running a routing SDM template (e.g. desktop-routing)
3750-Stack#sh sdm prefer
 The current template is "desktop routing" template.
 The selected template optimizes the resources in  the switch to support
 this level of features for
 8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:                  3K
  number of IPv4 IGMP groups + multicast routes:    1K
  number of IPv4 unicast routes:                    11K
    number of directly-connected IPv4 hosts:        3K
    number of indirect IPv4 routes:                 8K
  number of IPv4 policy based routing aces:         0.5K
  number of IPv4/MAC qos aces:                      0.75K
  number of IPv4/MAC security aces:                 1K
The important entry is:
"number of IPv4 policy based routing aces:         0.5K"
3)  You can only use redirect in statements on your L3 interfaces of the 3750.
4) If you are using a redirect list, the ACL can only have permit statements.
Mike Korenbaum
Cisco Data Center PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
Ian Beck Mon, 08/08/2011 - 08:26
The enetered command after upgrade was :
wccp tcp-promiscuous service-pair 61 62 router-list-num 1 l2-redirect
changed to
wccp tcp-promiscuous service-pair 61 62 router-list-num 1 l2-redirect mask-assign
and
        Routers Seeing this Wide Area Engine(1)
        Router Id       Sent To
        172.18.1.1      172.18.1.1
                -NONE-
                -NONE-
                -NONE-
        Router Id       Sent To
                -NONE-
                -NONE-
                -NONE-
UKHSL-WAAS02#
Many thanks
Ian
Michael Korenbaum Mon, 08/08/2011 - 09:01
Ian,
I see you were missing the mask assignment requirement.
Also note on the 3750 using show ip wccp 61 the counters there are software based, but this is a hardare based platform in terms of wccp redirection, so the counter "packets redirected" should not increment.
To verify redirection is working on your WAE use  "show wccp gre"
look for the line:
Transparent non-GRE packets received:          1186694
That should increment.
Then of course you would do show stat con to see the traffic (both PT and optimized).
Mike
Ian Beck Tue, 08/09/2011 - 01:18
If I change the WAAS configuration as suggested I go back to the same issue, broken.
If I revert back to L2 for Redirect Method the Switch and WAAS associate.
What Egress Method to use ?
Ian
Michael Korenbaum Tue, 08/09/2011 - 08:41
Jan,
That is incorrect, the 3750 only supports redirect method GRE and assignment method mask.
As Ian has observed if you change it GRE redirect or hash assignment (which is the default on WAAS), the WCCP adjacency will not form between the 3750 and WAE.
You should use the default ip forwarding egress method as that is the only one supported in your scenario (and the only one that makes sense, since your WAE has to be layer 2 adjacent to the switch and on it's own subnet).
Mike
Ian Beck Tue, 08/09/2011 - 08:52
So is this a bug and I need to revery to the previous version ?
Ian
Michael Korenbaum Tue, 08/09/2011 - 09:26
Ian,
This is not a bug, but was a misconfiguration.
In order to successfully do wccp between WAE and 3750 you must configure the WAE like this:
wccp router-list 8 14.110.3.17
wccp version 2
Mike
Ian Beck Tue, 08/09/2011 - 10:30
But it was stated that all redirects should be WCCP GRE.
Just wanting to clarify.
Ian
Ian Beck
Senior Networks Administrator
Mobile : 07969129410
Note : Sent from my Blackberry
Sent: Tuesday, August 09, 2011 05:27 PM
To: Ian Beck
Subject: - Re: WAAS 4.41 upgrade & WCCP
created by Michael Korenbaum in Wide Area Application Services (WAAS) - View the full discussion
Michael Korenbaum Tue, 08/09/2011 - 11:08
Ian,
I did not say redirect method shoud be GRE in this scenario, that was Jan.
For clarification purposes when doing WCCP redirection off a 3750 these are the requirements for the WCCP client (WAAS device in this instance).
Layer 2 adjacent to the 3750
Redirect method = L2
Assignment method = Mask
Here is a link which shows the unsupported wccp features.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_58_se/configuration/guide/swwccp.html#wp1051427
Hope this helps,
Mike
Ian Beck Tue, 08/09/2011 - 23:43
Many thanks for the clarification that was all I was after.
Rgards Ian
Ian Beck
Sent: Tuesday, August 09, 2011 07:09 PM
To: Ian Beck
