08-09-2011 04:10 AM - edited 03-07-2019 01:36 AM
I am looking for a cisco wireless router with built-in Modem, VPN, ADSL and firewall.
Can someone please advise, as the 850 series is EOL.
pei
Solved! Go to Solution.
08-09-2011 04:29 AM
i see from the EOL the replacement device for 850 series is
---Cisco 887 VDSL/ADSL over POTS Multi-mode Router
Data sheet link for cisco 887:
Hope this helps
cheers
Somu
Rate helpful posts
08-09-2011 04:35 PM
I think cisco 800 series does not have a built-in modem.
8X7 have "built-in" ADSL modem. So look at the 887 as what Somu has recommended.
08-09-2011 04:29 AM
Hope this helps
cheers
Somu
Rate helpful posts
08-09-2011 04:09 PM
I need one with built in modem
08-09-2011 04:35 PM
08-09-2011 05:15 PM
Thanks, how can you tell if the model comes with the built-in modem?
I read the spec on Cisco website, does "ADSL over POTS " refers to built-in modem?
08-09-2011 05:36 PM
Look at the last digit of the model number. 8X7 means it's got a built-in ADSL modem.
POTS stands for Plain Old Telephone System.
08-09-2011 05:20 PM
how about 877 is it as good as 887? 877 is cheaper.
08-09-2011 05:37 PM
True but the 887 has more "grunt" than an 877. What are you trying to do?
08-09-2011 05:59 PM
We need a router that can be used for VPN IPSEC access, Firewall, ADSL/ADSL 2+ and built-in Modem.
What is more of 887 than 877?
08-09-2011 07:36 PM
887 has a higher throughput than an 877.
When you purchase this, make sure you load up the maximum DRAM. You can never go wrong with this setup. Make sure you also specify what feature set you need and make sure you download the "crypto" version.
08-10-2011 04:46 AM
The 877 can also supports this. It's now up to you to decide between budget vs throughput.
