Bug Toolkit does not give search results back
Aug 9th, 2011
Today everytime I ran a search for known bugs in an IOS release it gives the page correctly but where results should be it is blank...
Is it just me? I tried already changing browser, PC and ISP...
thnks for your atention
Overall Rating: 5 (3 ratings)
asolleti Tue, 08/09/2011 - 10:09
Hi Davide
I observe similar issue. I have given the head's to the development/support team to help resolve the issue at the earliest.
Arun Solleti
jdanrich Tue, 08/09/2011 - 14:58
Same here!
It's horrible.. no response in either IE 8 or Firefox 5.
I have submitted a support email, but have no idea when this will be resolved..
asolleti Tue, 08/09/2011 - 16:40
Hi All
We have identified and resolved the issue.
Just verified to make sure the search is functioning correctly.
Arun
Steven Griffin Tue, 08/23/2011 - 10:02
Arun,
The issue still seems to be occuring as of today.  Using Firefox 6 or IE 8 I get zero search results.
-Steven
asolleti Tue, 08/23/2011 - 10:30
Hi Steven
Can you please provide criteria for your search operation (Bugid or Category/Product/Version etc) ?
I did a quick search on a product under "Router" category and got back results.
Arun
Steven Griffin Tue, 08/23/2011 - 10:42
I did two searches that came back blank:
In the first search, selected All IOS releases.  I chose the '12.4' train release '10c' and the third box was ANY.  I tried searching for MGCP and the results came back blank.
In the second search, I selected Communications Manager (Call Manager) and chose release 7.1.   I tried searching for mgcp and also tried RTMT.  Both results came back blank.
In both cases, if I do not put any search terms in, I get all results just fine
-Steven
Roger Wiklund Tue, 08/23/2011 - 10:40
I have the same problem.
I selected Routers -> Cisco 2800 ISR -> 12.4.24-T3 and searched for "floating". After Cisco logo animates I get a blank output.
The problem seems to be when you select "Known Affected Version (KAV)"
If you select "Fixed-in" or "Found-in" it works for me.
EDIT: If I select ANY instead of T3, I get blank output no matter what.
asolleti Tue, 08/23/2011 - 16:11
Steven & Roger
Thanks for providing the search criteria. Looks like use of keyword & Known Affected Version (KAV) combination together results into this behavior.
I have asked our development team to look into it.
Arun
ktang Wed, 08/24/2011 - 04:02
I'm having this issue as well for 'Voice and unified communications > cisco unified intelligence suite and intelligence centre', version 8
Rob Huffman Wed, 08/24/2011 - 05:51
Hi Arun,
Yes, no search results here either
Voice and Unified>Callmanager>6.1>route is one example
Page spins for a minute then yields no results. When using BSS there are 220
results.
Cheers!
Rob
asolleti Wed, 08/24/2011 - 07:58
Rob, Kent, Steven & Roger
Only work around that i have tested and worked multiple times, is not entering the keyword.
If you dont enter the keyword, then search results does come back for all scenarios mentioned above.
While it might not be a helpful workaround, but atleast tool will not block you from getting results (when not using keyword).
Thanks for your patience, while we are attempting to fix the problem.
Arun
pdotchon Wed, 08/24/2011 - 13:14
Hi, this issue is still apparent and is pretty serious in my view,  effectively the tool is broken. Do we have a view of how long this will  take to resolve, I assume this is a high priority fault for Cisco so I'm  somewhat surprised it hasn't been resolved yet.
Phil Dotchon
Martha van Berkel Wed, 08/24/2011 - 14:28
Hi Rob, Phil, Steven, Roger, Davide, Kristine and other Bug Toolkit users,
My name is Martha Garriock and I am the Senior Manager, responsible for our online troubleshooting tools. Phil you are absolutely right, our tool is broken. In fact, this is only one of two major issues that my team is working on. We recognize that the blank page issue, and the performance issues that you are all experiencing is totally unacceptable.  Please know that we have our best people working on it, and as soon as we have line of sight of a fix, we will be on this forum letting you know.  Please keep the feedback coming, especially with details on what you are trying to search, as it helps in our troubleshooting.
The good news is that our team is working on getting you a brand new Bug Search Tool - one that is fast, easy to use, and gives you a voice in rating the quality of our release notes (future release). This tool is currently in Beta, and while it isn’t perfect (we are working on making it easier to use, navigate, and works with localized settings in browsers), it works ! We encourage you to use it while we fix the BTK issue.  We also encourage you to provide us feedback on this new tool, as we continue to refine it before General Availability.
Cisco Bug Search Service URL : www.cisco.com/cisco/psn/bssprt/bss
Bug Search Service Help Page : http://www.cisco.com/web/applicat/cbsshelp/help.html
Bug Search Service release notes for known issues: http://www.cisco.com/web/applicat/cbsshelp/releaseupdate.html
Please accept my apologies on the state of Bug Toolkit, and please know that both my team, and my management team are doing everything possible to get it resolved.
Cheers,
Martha Garriock
Senior Manager, Support Web Troubleshooting Tools
[email protected]
416-306-7047
pdotchon Thu, 08/25/2011 - 03:51
Hi Martha,
Thanks very much for the update and explanation, much appreciated and very reassuring! I will try out the new search tool and let you know if I run into trouble
Cheers,
Phil Dotchon
Senior Advisory Specialist
IBM Global Technology Services
Cisco Certified Internetworking Expert #6632
Cisco Certified Wireless Design Specialist
Cisco Certified Advanced Wireless Field Specialist
pdotchon Thu, 08/25/2011 - 03:52
Hi Martha,
into trouble
Cheers,
Phil Dotchon
IBM Bristol, No.1 The Square, Temple Quay, Bristol BS1 6DG
Telephone: +44 (0)117 929 5953
Mobex: 37273911 Mobile: +44 (0)7802 936 744
Email: [email protected]
"Network: anything reticulated or decussated at equal distances with
interstices between the intersections"
Samuel Johnson 1755. Just goes to prove that networking has always been
complicated.
mgarrioc
24/08/2011 22:28
Please respond to
"[email protected]"
To
Philip Dotchon/UK/[email protected]
cc
Subject
- Re: Bug Toolkit does not give search results back
created by Martha Garriock in Bug Toolkit - View the full discussion
currently in Beta, and while it isn?t perfect (we are working on making it
easier to use, and navigate), it works ! We encourage you to use it while
get it resolved.
Cheers,
Martha Garriock
[email protected]
416-306-7047
Reply to this message by going to Cisco Support Community
Start a new discussion in Bug Toolkit at Cisco Support Community
Unless stated otherwise above:
IBM United Kingdom Limited - Registered in England and Wales with number
741598.
Registered office: PO Box 41, North Harbour, Portsmouth, Hampshire PO6 3AU
Steven Griffin Thu, 08/25/2011 - 08:26
Martha,
Thank you and your team for working to resolve this issue.  I can tell you that the bug toolkit is one of the most valuable resources Cisco has on CCO.  I don't think I am alone in saying that this tool has saved me untold time and calls to TAC.  I look forward to using the new tool.
-Steven
Rob Huffman Thu, 08/25/2011 - 05:31
Hi Martha,
Hope all is well my friend (other than this issue )
Well everything seems to be working well for me today with BTK. I tried the
same search as previously;
Voice and Unified>Callmanager>6.1>"keyword" route
And the search yielded the desired results (if Bugs can be desired results )
A BIG thank you to you, Arun and your whole team who worked on solving this issue!
Cheers!
Rob
asolleti Thu, 08/25/2011 - 07:30
Hi Rob
Thanks for the confirmation.
Development team identified the problem and fixed the issue and we will continue to monitor this going forward to make sure everything works fine.
Arun
