ACS 5.2 - Adding Custom Attributes for Juniper Netscreen TACACS+ Authentication
Answered Question
Aug 10th, 2011
I am trying add custom attributes for Juniper Netscreen TACACS+ authentication to a v5.2 ACS. The advice is to add it to the group as follows:
ervice = netscreen {
vsys = root
privilege = read-write
I know how to add this to a version v4.x ACS
However, I do not know how to apply this to the custom attribiutes to a v5.x ACS
Do I add the vsys and privilege attribute seperately or together? What should be the attribute name? netscreen? Should it be mandatory?
Any advice please
Overall Rating: 5 (1 ratings)
Good question, I'd like to know this as well for the netscreens. For junos, this is how I tried to do it (you would drop the "netscreen" from yours, but not sure if you would add both as mandatory)
Acs4.x setup
junos-exec
  local-user-name=readonly
acs5.2 setup
attribute -  local-user-name
value - readonly
mandatory
# junos config
    login {
        class admin {
            idle-timeout 30;
            permissions all;
        class read-only {
            idle-timeout 30;
            permissions [ view view-configuration ];
        user admin {
            class admin;
        user readonly {
            class read-only;
The problem I have though, is this fixes my login to work to my JunOS devices, but it breaks the authentication to my Cisco IOS devices. The AAA logs show that the authentication succeeded, but the router says "authorization failed". Once I remove either the attribute from my shell profile, or make it optional then the Cisco router works for auth, but the JunOS device stops working (The username it tries to use is "remote" instead of the user I am trying to authenticate with).
rodmunch999 Mon, 08/15/2011 - 22:23
Bingo! Thank you very much Justin - I still had the privilege levels set to 15 but when I removed them but kept in the new attributes it logged in fine.
rommel-peraza Thu, 02/09/2012 - 05:15
Hi, I was looking for some help on configuring a Juniper FW on my Cisco ACS v4.0 and I found you guys. Can you tell me which would be the best way to do that or where can I find good documentaction about it?
Thanks.
cburgers Wed, 09/04/2013 - 19:27
Has anyone managed to find out why the cisco devices fail authorization when the mandatory custom attribute is enabled?
Justin said
"The problem I have though, is this fixes my login to work to my JunOS  devices, but it breaks the authentication to my Cisco IOS devices. The  AAA logs show that the authentication succeeded, but the router says  "authorization failed". Once I remove either the attribute from my shell  profile, or make it optional then the Cisco router works for auth, but  the JunOS device stops working (The username it tries to use is "remote"  instead of the user I am trying to authenticate with)."
I am currently having the same issue with ACS5.4.
Craig
cburgers Thu, 09/05/2013 - 21:07
Thanks Justin,
I was hoping to use just one shell profile for both device groups. We have it working with seperate profiles, but would be less overhead with one!
I havn't tried NXOS yet, but I imagine it will be a similar story.
Craig
Related Content
