SIP trunk incoming callto CUCM 7.1.5 - authorization problem.
Aug 12th, 2011
Hi everybody.
Just run into the strange problem - if SIP trunk uses digest authentification then CUCM 7.1.5 behavesin a strange way.
Incoming call goes like that:
1st invite goes without digest credentials.
After "401 Unauthorized" goes ACK and INVITE with all needed credentials.
But after that again goes "401 Unauthorized" !
INVITE sip:200@10.1.1.221 SIP/2.0
               SIP/2.0 100 Trying
               SIP/2.0 401 Unauthorized  WWW-Authenticate: Digest realm="BOINC" ...
ACK sip:200@10.1.1.221 SIP/2.0
Authorization:  Digest username="cucm71",realm="BOINC",nonce=......
               SIP/2.0 100 Trying
I checked in the CUCM trace and found that digest user is not found
08/12/2011 13:02:05.005 CCM|ProcessSIPSecurity - can't find user cucm71 in the user table . Authorization fail.
But "cucm71" user is there.
If no digest authentification is used then, of course, incoming calls are OK.
With CUCM 6.1 I never have such problem.
Any clue?
mitchell.drage Sat, 04/21/2012 - 05:39
Any chance you got this to work?
I am having a similar problem where I have the application user configured and it denies me:
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 10.1.100.1:5060;branch=z9hG4bKF41929
To: ;tag=1504004667
Date: Sat, 21 Apr 2012 12:34:05 GMT
Call-ID: B2EB9BA8-8AE411E1-887EF97A-F80FE12A
CSeq: 5 REGISTER
Warning: 399 CUCMPUB "Unable to find device/user in database"
Content-Length: 0
sip-ua
credentials username SIPTEST password 7 ********* realm test
retry invite 2
retry register 10
timers connect 100
registrar ipv4:10.1.10.100 expires 3600
sip-server ipv4:10.1.10.100
host-registrar
Mitch
Alexey Platov Tue, 04/24/2012 - 02:35
I did manage it.
It was my negligence - you should manage "Digest Credentials" for this Application User not onle name and password! And your SIP trunk should use name and digest credentials configured.
mitchell.drage Tue, 04/24/2012 - 04:54
Yeah I noticed that yesterday from your image.
I think my problem is caused by something else despite following the cisco guide to the tee.
I'll start a new thread rather than continue from yours.
Good to hear you found a solution for your problem.
Venkkatesh Laks... Tue, 01/27/2015 - 08:09
Go to the trunk and check the sip security profile associated with this trunk.
uncheck the enable Digest Authentication in Device trunk security profile in the cucm.
reset the profile.
Related Content
