CISCO ACE issue with MIBs
Answered Question
Aug 14th, 2011
Dear All,
  I know this might have discussed here million times.. but still i am behind this to get this done due to BU pressure to do the capacity management.
I am trying to get the following using SNMP
1) Real Server
2) Real Server Current Connection
3)  Real Server IP address
I tried it with following MIBs and OIDs
CISCO-SLB-MIB
slbRealServerFarmName               .1.3.6.1.4.1.9.9.161.1.3.1.1.1
slbRealIpAddress                          .1.3.6.1.4.1.9.9.161.1.3.1.1.2
slbRealNumberOfConnections         .1.3.6.1.4.1.9.9.161.1.3.1.1.5
CISCO-ENHANCED-SLB-MIB
cesRserverName                         .1.3.6.1.4.1.9.9.470.1.1.1.1.1
cesRserverIpAddress                    .1.3.6.1.4.1.9.9.470.1.1.1.1.4
cesRserverCurrConns                   .1.3.6.1.4.1.9.9.470.1.1.1.1.19
Either of these MIBs /OIDs return any value.
When i raise a TAC case i got the information saying these cannot be retrieved.
Is there any way i can get these values from ACE MODULE , because this is very much required for the BU and they are behind us since long time.
Apppreciate support from all.
thanks,
Parvees
Correct Answer by AlexandrKry about 5 years 8 months ago
Hi Parvees,
I wasn't looking for values you're interested in, but everything you can get with show command you can get via HTTP(s) request in XML using .
For example, here's a "sh serverfarm ServerFarm1" query:
$  curl --user USER:PASSWD -d "xml_cmd=CONTEXT\">xml-show on%0A show serverfarm ServerFarm1" http://ACE_IP_ADDRESS/bin/xml_agent
I'm running curl on linux box, but I think it is available on other platforms. The code above is a one-line command, but you can write scripts/lists of commands and send them to your ACE with curl.
Here's a link provided in a neighbour discussion that gives more information: https://supportforums.cisco.com/docs/DOC-17849
Hope this help,
Alex
Overall Rating: 5 (1 ratings)
AlexandrKry Mon, 08/15/2011 - 04:55
I'm not sure about the items you're asking for, but I tried to get resources usage via SNMP and didn't find it.
I snmpwalk'ed through all the items on ACE, but didn't find anything particularly interesting to me. In fact, I was surprised that SNMP support is very poor on ACE (ACE-20).
As a hackaround you can retrieve the values you're interested in using XML interface.
parveesm123 Mon, 08/15/2011 - 20:07
Alex,
Were you able to retrieve the value for show serverfarm XXX  or show real server commands
could you please assist me in creating XML script for the same since i am a newbie to this
-Parvees
Correct Answer
AlexandrKry Mon, 08/15/2011 - 22:30
Hi Parvees,
Hope this help,
Alex
parveesm123 Mon, 08/15/2011 - 23:14
Alex,
Excellent..You are the champ... I got what i required.... thanks a ton :-)
-Parvees
Marko Leopold Mon, 08/15/2011 - 23:15
You can try out Cacti. There is an ACE-template. And if you check out the Poller-Cache you will get the SNMP-OID of the RServer. It's a bit of work to do, but in the end you get your OIDs. The OIDs are extremely long, because they have the name of the rserver included.
parveesm123 Mon, 08/15/2011 - 23:25
Merko,
We required a centralised monitoring system and it is HPOV. Currently we are using SNMP , but MIBs and OID which i tested for rserver connection didnt provided any value.
HPOV team told they can fetch the values from XML scripts.. that is why thought of this option
-Parvees
