08-15-2011 11:25 AM - edited 03-11-2019 02:11 PM
I recently upgraded Java to JRE version 1.7.0 and now when I try to login to the ASA 5510, I get the following message in the java console log.
Exception in thread "AWT-EventQueue-0" java.lang.ClassCastException: sun.security.ssl.X509TrustManagerlmpl cannot be cast to com.sun.net.ssl.internal.ssl.X509ExtendedTrustManager
at com.sun.deploy.security,X509ExtendedDeployTrustManager.<init>(Unknown Source)
I have attached the log file (2 pages).
08-18-2011 01:47 AM
Hi Tom,
ASDM is not currently supported with JAVA version 7. The exception you see above is typically generated. I suggest you downgrade java version to 6.
An enhancement request has been files for this:
You will be able to view this bug after 24 hours.
Hope this helps!
Anu
P.S. Please mark this question as resoved if it has been answered. Do rate helpful posts. Thanks!
10-16-2014 02:03 PM
Thank you this fixed my problem also.
07-27-2012 04:28 PM
Quick workaround is to change your ASDM launcher shortcut to point to Java 6 which may well still be on your client. Assuming it's Windows 7, look at the Control Panel -> Programs and Features, and you'll probably find a few different versions of Java there. Typically, the ASDM launcher shortcut target will end up looking something like this:
"C:\Program Files\Java\jre6\bin\javaw.exe" -Xms64m -Xmx512m -Dsun.swing.enableImprovedDragGesture=true -classpath lzma.jar;jploader.jar;asdm-launcher.jar;retroweaver-rt-2.0.jar com.cisco.launcher.Launcher
08-16-2012 06:49 PM
Thanks Steve, your workaround works for me.
I found Java 6 and made a shortcut to it with your stuff added:
Target: "C:\Program Files (x86)\Java\jre6\bin\javaw.exe" -Xms64m -Xmx512m -Dsun.swing.enableImprovedDragGesture=true -classpath lzma.jar;jploader.jar;asdm-launcher.jar;retroweaver-rt-2.0.jar com.cisco.launcher.Launcher
Start in: "C:\Program Files (x86)\Cisco Systems\ASDM\"
So I can keep running Chrome and the latest version of Java elsewhere. I hope that is useful to others as well
01-03-2013 01:22 PM
Steve:
Thank you EVER so much for your assistance! I have been battling with this for two days; when I saw this particular thread the problem was resolved in minutes. Again, my thanks.
07-28-2012 12:03 PM
Hi Bro
You could refer to https://supportforums.cisco.com/thread/2159707
