Mapping Drive using SSL VPN
parveesm123
Can I mape a drive letter using SSL VPN.
that is when i connect client less SSL VPN , and once it authenticates ,I need to automate Drive "G" to be mapped to my PC.
is it possible
thanks,
Parvees
Jennifer Halim
Yes, you can configure script to run after the SSL VPN is connected.
Here is the configuration guide for your reference:
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect25/administration/guide/ac03features.html#wp1068902
Hope this helps.
