ACE NAT configuration - is it possible to use a different source PAT IP per rserver in a serverfarm?
Aug 15th, 2011
I've a quick question regarding using PAT (port address translation) on an ACE module specifically for the purpose of load-balancing requests to a cluster of Exchange CAS servers.
Each CAS server needs to see requests from the same source IP which can be achieved by using source NAT / PAT but due to the scale of this Exchange deployment a single NAT pool with one PAT'd IP will not provide enough ports (i.e. there may well be more than ~64,000 ports required at any one time).
Is it possible to configure PAT on the ACE so that each individual rserver will see requests from a unique source PAT address, i.e., each rserver sees a different source PAT IP, i.e., in order to provide ~64,000 ports per source PAT IP <-> CAS server pair as opposed to ~64,000 ports shared between all the CAS servers?
If so, does anyone have any configuration examples (based on a single-armed configuration)?
TIA
ohynderi Wed, 08/17/2011 - 01:32
  • Cisco Employee,
Hi Tia,
I don't think we can do this. We can easily configure a different nat pool per serverfarm but not per rserver.
--Olivier
Related Content
