Question about CSM and SSLM with NAT
jimmychanga
When using a CSM and SSL-M, which piece of the configuration is responsible handling client NAT? I have a need to NAT all client addresses as coming from the "loadbalancing network". Im currently configured to do that on the CSM for traffic leaving the SSL-M destined for the webservers. While I can see the traffic hit the server and a reply being returned by the servers, the response does not appear to make it back to the client.
Are there any configuration examples that show how to use CSM, SSLM and NAT together?
ohynderi
Both CSM and SSLM can be configured to perform client nat. Is the traffic hitting the sever being source natted properly?
You said that the server response doesn't not appear to reach the client. Are you talking about http responses or any packets from server to client?
Does it work fine without client nat?
Can you show me the relevant part of your CSM and SSLM config?
--Olivier
