Business Attendant Console Client License
h_ramdolin
Dear All,
I have a license for CUBAC Server and the software is fully activated to full version. However my CUBAC client is still on evaluation mode. Do I need a seperate license for the CUBAC Client?
Thanks.
5 Replies 5
I have met on this before.
Can't remember exactly but if you restart the client workstation and it doesn't fix the problem try to reinstall the client and see if the evaluation goes away.
But definately you do not need a license for the client seperately.
craigleitch32
Restart the services on the server and then log in to the client again, this should fix your issue.
That is correct, if you restart the Cisco services on the CUBAC server the client will no longer get that message. There is no seperate user and server license.
Good answer !
This trick works as well for the CUAC Advanced.
Just restart the service "Cisco Unified Attendant Server" and then log in / log out the attendant console client.
I have confirmed that restarting the services also works on Enterprise version 9.
