WLC Custom Web Auth Bundle sample .tar file is not on WCS
Aug 17th, 2011
The WLC documentation would make it appear (or maybe previously) you should download a sample web auth bundle code from the WCS Templates. I was never able to find a sample .tar file on the WCS 7.0.172.0 templates.
However I found on Cisco.com under Support > Downloads > Products >Wireless> Wireless LAN Controller Standalone Controllers> Cisco 5500 Series Wireless Controllers > Cisco 5508 Wireless Controller > Wireless Lan Controller Web Authentication Bundle-1.0.2  > webauth_bundle-1.0.2.zip
It was updated in June 2011, some pretty good sample html code.
The readme.html in the sample webauth_bundle-1.0.2.zip file has been very helpful , almost as good as the suppport community web page on custom web auth.
https://supportforums.cisco.com/docs/DOC-13954
Kayle Miller Tue, 08/23/2011 - 06:50
Nicolas is correct is all counts. That is the process in 7.0.172.0 but the web-auth bundle templates you can get off cisco.com are far better and give more options for the web-auth bundle page options.
Related Content
