Cisco 3560 v2Series 24 port Simple....copy config from one switch to another
Answered Question
Aug 18th, 2011
Ok this should be simple copy the config from one switch onto notepad and copy from notepad and paste into the switch.... same model etc...
Switch is new out of the box
enable
conf t
then paste
Right???  I keep getting invlaid marker errors when I am pasting in user logins also doing small chunks as I copy and paste
Correct Answer by Amit Aneja about 5 years 7 months ago
Not sure why it goes out from config to privilege mode, go into config mode again & copy/paste from "hostname".... Else easier way as Alain suggested, backup the config on a TFTP & copy the config from TFTP back to new router's flash.
Follow this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml#backup
Amit
Overall Rating: 5 (1 ratings)
Amit Aneja Thu, 08/18/2011 - 12:53
  • Bronze, 100 points or more
Let's look at a chunk where you are getting the invalid input & see what's wrong.
Paste the o/p that you are getting.
navigatorvictory Thu, 08/18/2011 - 13:21
Would you like to enter the initial configuration dialog? [yes/no]: no
Switch>enable
Switch#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Switch(config)#!
Switch(config)#line con 0
Switch(config-line)# login local
Switch(config-line)#line vty 0 4
Switch(config-line)# exec-timeout 60 0
Switch(config-line)# logging synchronous
Switch(config-line)# length 0
Switch(config-line)#line vty 5 15
Switch(config-line)#!
Switch(config-line)#ntp clock-period 36028469
Switch(config)#ntp server 10.93.250.9
Switch(config)#end
Switch#
Switch#Current configuration : 15856 bytes
% Invalid input detected at '^' marker.
Switch#
Switch#version 12.2
Switch#no service pad
Switch#service timestamps debug uptime
Switch#service timestamps log uptime
Switch#service password-encryption
Switch#!
Switch#hostname FGG150-SWITCH-4
Switch#!
Switch#boot-start-marker
Translating "boot-start-marker"...domain server (255.255.255.255)
% Unknown command or computer name, or unable to find computer address
Switch#boot-end-marker
Translating "boot-end-marker"...domain server (255.255.255.255)
Switch#!
*Mar  1 00:03:06.352: %SYS-5-CONFIG_I: Configured from console by console
navigatorvictory Thu, 08/18/2011 - 13:22
notepad version
line con 0
login local
line vty 0 4
exec-timeout 60 0
logging synchronous
login local
length 0
line vty 5 15
exec-timeout 60 0
logging synchronous
login local
length 0
end
version 12.2
no service pad
boot-start-marker
boot-end-marker
navigatorvictory Thu, 08/18/2011 - 13:25
I took this part out
version 12.2
no service pad
Then it would not error at first but when it hit hostname it again did not like something
I thought all you had to do was go to old switch and do a show run copy what you see to notepad and go
cadet alain Thu, 08/18/2011 - 13:40
  • Purple, 4500 points or more
The router was complaining because you were entering commands in the wrong mode.
Copying running to save it on a host is ok but other way is not the right way to do it as you saw.
just do a copy ftp:// xxxx   running or copy tftp:// xxxx running, it will be less troublesome.
Regards.
Alain.
Correct Answer
Amit Aneja Thu, 08/18/2011 - 13:47
Follow this link:
Amit
