multicast mvrf design question
Answered Question
Aug 20th, 2011
Hello everyone!
I got a task to implement multicast traffic throug different vrfs in existing network topology.
There is 2 vrfs: server and pc. The work separatelly, but there is a router r2 (central site), where vrfs server and pc are merged in additional vrf common (central vrf). Also, 2 route reflectors are in this topology, so all other routers are route-reflector clients of both route-reflectors. All interfaces are in sparse-dense mode, multicast and vrf multicast has already enabled as well as mdt relatonships with route-reflectors.
Now it works well using unicast, but I need to change this traffic to a multicast one.
I can't change neigher topology nor vrf import/export configuration. I am hesitating about is it possible to make multicast traffic flows between vrf's in this situation.
Green lines are described server vrf (ip vrf server)
Red lines are described pc vrf (ip vrf pc)
Black lines are described mpls lines (mpls ip)
At least multicast flows shoud work as described using blue lines
Please, give some advices about best solution to my issue:
1) how to plan mdt domains
2) how to plan pim exchange
3) may be some else
I don't know what information I can give more in this case, so it could be provided on demand.
Thank you.
Correct Answer by Giuseppe Larosa about 5 years 11 months ago
Hello Evgeny,
it is correct to say that this thread is closely related to the other one you have opened today?
if so I would suggest to go on that thread
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 08/23/2011 - 06:43
  • Hall of Fame,
    Founding Member
Hello Evgeny,
Hope to help
Giuseppe
eugene.fit Tue, 08/23/2011 - 22:54
Hello, Giuseppe. You abossutelly right, it is about the same, Let's consider this topic closed
Related Content
