How to Block Teamviewer application on ASA5510
tabish bhat
Guys, i need your help i want to block teamviewer for certain ip adds
Any idea...
Tabish Bhat.
6 Replies 6
Anu M Chacko
Hi Tabish,
Could you please try the following and let me know?
regex teamviewer “\.teamviewer\.com”
class-map type regex match-any block
match regex teamviewer
class-map allow_teamviewer
match access-group allow_teamviewer
access-list allow_teamview permit ip
policy-map type inspect http http-pol
parameters
match request header host regex class block
drop log
policy-map global_policy
  class allow_teamviewer
You can specify the IP addresses in the class-map allow_teamviewer. Hope this helps!
Anu
P.S. Please mark this question as answered if it has been resolved. Do rate helpful posts. Thanks!
Hi Anu,
Thanks for your prompt reply !!
I tried MPF given by you, but it did not work !
Tash
Hi Tash,
Could you try it without the access-list and see if it gets blocked?
parameters
drop log
  class inspection_default
Let me know.
Anu
Hi Anu,
I tried without access-list still it is not working
Tash Bhat
Hi Tash,
You are trying to access "teamviewer.com" right? Let's try blocking DNS requests to this site. Try this:
regex teamviewer “\.teamviewer\.com”                     //This is "slash","dot","teamviewer","slash","dot","com"
policy-map type inspect dns dns-pol
parameters
message-length maximum 512
match domain-name regex class block
drop log
  inspect dns dns-pol
Let me know.
Anu
Hi Anu,
For your information i am trying to block teamviewer application not website,The problem is even if i am trying to block url also, it is not blocking it
i am confused why MPF is not working ,i also tried to block "teamviewer.com" but it is not happening......May be the "regex" is not matching
what to do now ?
Tash Bhat
