Tarquin Joseph Fri, 09/02/2011 - 10:08
Hi Nilesh,
It supports configuration professional express (embedded) or you can use the CCP application externally on a PC.
Possibly the CCP express files have been deleted.  Can you do a dir flash: to show the contents of the flash drive?
T.
tsmith4000 Tue, 03/06/2012 - 00:52
I have same problem, disable Use TLS 1.0 in the Java control panel
Torben
diek Mon, 12/17/2012 - 06:47
I have the same problem on a 1921 router and disabled the Java/advanced /security/general/Use TLS 1.0 and I get the same error message. Followed the "Cisco Configuration Professional Quck Start Guide" tips o page 15 and still getting the same error message. Anyone else had this and know what fixes it.
Ken
