SFP validation failed
We have a Cisco Nexus 4000 switch with the following transcievers and I can't get a link to other 850 nm, sr,  mm interfaces.
sho interface ethernet 1/15 transceiver
Ethernet1/15
    sfp is present
    name is FINISAR CORP.
    part number is FTLX8571D3BCL
    revision is A
    serial number is AL404N7
    nominal bitrate is 10300 MBits/sec
    Link length supported for 50/125um fiber is 82 m(s)
    Link length supported for 62.5/125um fiber is 26 m(s)
    cisco id is --
    cisco extended id number is 4
hchassis# sho int eth1/15
Ethernet1/15 is down (SFP validation failed)
  Hardware: 1000/10000 Ethernet, address: 0027.0d24.305e (bia 0027.0d24.305e)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10g
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  Last link flapped never
  1 minute input rate 0 bits/sec, 0 packets/sec
  1 minute output rate 0 bits/sec, 0 packets/sec
  Rx
    0 input packets 0 unicast packets 0 multicast packets
    0 broadcast packets 0 jumbo packets 0 storm suppression packets
    0 bytes
  Tx
    0 output packets 0 multicast packets
    0 bytes
    0 input error 0 short frame 0 watchdog
    0 no buffer 0 runt 0 CRC 0 ecc
    0 overrun  0 underrun 0 ignored 0 bad etype drop
    0 bad proto drop 0 if down drop 0 input with dribble
    0 input discard
    0 output error 0 collision 0 deferred
    0 late collision 0 lost carrier 0 no carrier
    0 babble
    0 Rx pause 0 Tx pause
  0 interface resets
I have attached the sho run all output. Any idea why I can't get an link out of this? Thank you very much for your time.
Tom Randstrom Mon, 08/22/2011 - 10:22
  • Gold, 750 points or more
Is the SFP installed in the device a Cisco labelled product or a third-party labelled device?  Cisco SW runs a check to verify the SFP is compatible before allowing it to operate.
I am assuming even thought the website claims that the FTLX8571D3BCL is Cisco compatible, that it is not. And the
"sho interface ethernet 1/15 transceiver" repsonse "cisco id is --" is proof of that?
I saw some other FTLX8571D3BCL online that had -cs added to the model number. I am guess this difference in model number has caused our failure? I have no clue. All I know is it won't link.
Nowhere on the device does it say Cisco. Thank you.
