UCCX8.5 with CUIC8.5 Reporting
Aug 22nd, 2011
Does anyone try to use CUIC8.5 to make custom reports for UCCX8.5?
I see in the UCCX roadmap that it will be supported in UCCX 8.6.
But I see in the CUIC data source configuration also support informix DB.
So I'm not sure if there is any problem if I use UCCX8.5 with CUIC8.5.
Tinnakorn
Overall Rating: 4 (2 ratings)
Gajanan Pande Mon, 08/22/2011 - 22:52
Tinnakorn,
AFAIK about the UCCX support with CUIC, it wont be introduced before UCCX 9.0. Could you please share the roadmap details that you have ?
GP.
Gajanan Pande Tue, 08/23/2011 - 07:03
Well, as of latest the confirmed information from BU is, We will have CUIC on UCCX as part of the UCCX 9.0 release (June/July 2012) no earlier UCCX versions if any.
Tinnakorn Mukud... Mon, 08/22/2011 - 23:58
I unterstand that it is not officially support in UCCX8.5.
Just want to know can it be done technically.
Gajanan Pande Tue, 08/23/2011 - 07:06
Technically it appears possible, because CUIC just needs data source & it is able to recognize informix db as data source. It should work.
Hope it helps ? Please rate if it does.
GP.
