ASR9k A9K-iVRF-LIC license Question
Hi.
I'm having problems with the vrf license in ios-xr. I have installed the VRF license and it seems to be working. But when i commit the vrf config the following error message appears in the logbuffer;
%LICENSE-ASR9K_LICENSE-2-INFRA_VRF_NEEDED : 1 VRF(s) are configured without a valid license / license configuration A9K-iVRF-LIC in violation of the S...
Some outputs from the router;
sh license
FeatureID: A9K-iVRF-LIC (Slot based, Permanent)
  Total licenses 1
  Available for use         1
  Allocated to location     0
  Active                    0
  Store name             Permanent
  Store index               1
    Pool: Owner
      Total licenses in pool: 1
      Status: Available     1    Operational:    0
sh license log administration
#ID     :SDR     :FeatureID       :NodeID    :Time:   Log
1       :Owner   :None            :0/RSP0/CPU0:Thu May 19 14:16:07 2011:   License add successful for feature(s): "A9K-iVRF-LIC"  License command "license add disk0:/xxx.lic sdr Ow
sh license log operational
29      :Owner   :A9K-iVRF-LIC    :0/1/CPU0  :Tue Aug 23 10:52:12 2011: license_acquire: opaque_string (null), result('License Manager' detected the 'warning' condition 'No such license')
I really dont understand what the trouble is all about. Any ideas?
Andreas
xthuijs
hi andreas,
in releases after 40x you need to manually assing the license to the slot.
from your output it seems that you have not assigned that lic yet, as it shows avaiable.
these are the steps:
RP/0/RSP0/CPU0:A9K-BNG#admin
Tue Aug 23 12:34:52.569 EDT
RP/0/RSP0/CPU0:A9K-BNG(admin)#conf
Tue Aug 23 12:34:53.678 EDT
RP/0/RSP0/CPU0:A9K-BNG(admin-config)#license NAME location ?
  0/0/CPU0     Fully qualified location specification
  0/1/CPU0     Fully qualified location specification
  0/RSP0/CPU0  Fully qualified location specification
  0/RSP1/CPU0  Fully qualified location specification
  WORD         Fully qualified location specification
  all          all locations
Xander Thuijs, CCIE #6775
Sr. Tech Lead ASR9000
27 Replies 27
xthuijs
hi andreas,
  all          all locations
Hi, Xander:
I'm having trouble adding a license to a slot for VRF. After adding the license to admin-config, shouldn't it appear as 'active'. Can you please help?
Thanks in Advance!
c.
RP/0/RSP0/CPU0:R01#admin
Mon Dec 10 18:14:35.004 UTC
RP/0/RSP0/CPU0:R01(admin)#show license
Mon Dec 10 18:14:38.019 UTC
FeatureID: A9K-MOD80-AIP-SE (Slot based, Permanent)
  Total licenses 2
  Available for use         2
  Active                    0
  Store index               1
    Pool: Owner
      Total licenses in pool: 2
      Status: Available     2    Operational:    0
RP/0/RSP0/CPU0:R01(admin)#show run
Mon Dec 10 18:14:40.970 UTC
Building configuration...
!! IOS XR Admin Configuration 4.2.3
username cisco
group root-system
secret 5 XXXX
end
RP/0/RSP0/CPU0:R01(admin)#conf t
Mon Dec 10 18:14:44.462 UTC
RP/0/RSP0/CPU0:CE.HTCHP.RPE01(admin-config)#license A9K-MOD80-AIP-SE location $
RP/0/RSP0/CPU0:R01(admin-config)#commit
Mon Dec 10 18:15:10.406 UTC
RP/0/RSP0/CPU0:R01(admin-config)#exit
Mon Dec 10 18:15:19.396 UTC
  Total licenses 2
  Available for use         2
  Active                    0
  Store index               1
    Pool: Owner
few requirements:
1) there needs to be an interface in a vrf configured on that linecard
2) the license needs to be assigned to the slot
RP/0/RSP0/CPU0:A9K-BNG(admin-config)#license X location 0/0/CPU0
3) the right linecard needs to be present in the slot that you assign the license to. It needs to match the linecard type for the license applied.
xander
All those things are correct:
RP/0/RSP0/CPU0:R01#show diag summ
Mon Dec 10 18:27:54.429 UTC
NODE module 0/RSP0/CPU0  ASR9K Route Switch Processor with 440G/slot Fabric and 12GB
NODE module 0/RSP1/CPU0  ASR9K Route Switch Processor with 440G/slot Fabric and 12GB
NODE module 0/0/CPU0  80G Modular Linecard, Service Edge Optimized
SPA 0/0/0 : ASR 9000 20-port 1GE Modular Port Adapter
NODE module 0/1/CPU0  80G Modular Linecard, Service Edge Optimized
SPA 0/1/0 : ASR 9000 20-port 1GE Modular Port Adapter
RP/0/RSP0/CPU0:R01#
RP/0/RSP0/CPU0:R01(admin)#license add disk0:FOX1643GG6U_201212091241520450.lic
Mon Dec 10 18:32:51.573 UTC
Info: License add successful for feature(s): "A9K-MOD80-AIP-SE"
License command "license add disk0:FOX1643GG6U_201212091241520450.lic sdr Owner" completed successfully.
Mon Dec 10 18:32:57.960 UTC
Mon Dec 10 18:33:00.438 UTC
No configuration changes to commit.
RP/0/RSP0/CPU0:R01(admin-config)#license A9K-MOD80-AIP-SE
RP/0/RSP0/CPU0:R01(admin-config-feat)# location 0/0/CPU0
RP/0/RSP0/CPU0:R01(admin-config-feat)#commit
Mon Dec 10 18:33:06.099 UTC
RP/0/RSP0/CPU0:R01(admin-config-feat)#exit
RP/0/RSP0/CPU0:R01(admin)#exi
RP/0/RSP0/CPU0:R01#sh license
Mon Dec 10 18:33:16.104 UTC
  Total licenses 2
  Available for use         2
  Active                    0
  Store index               1
    Pool: Owner
RP/0/RSP0/CPU0:R01#
never mind. thanks a lot!!!!
Ok perfect!
xander
I see the outputs confirming 2 and 3.
but do you have an interface on LC0 in a vrf with an addr assigned?
xander
Hello Alexander, how are you?
I'm having the same issue with the module ASR9000V, I have applied the license to all locations but It doesnt show up as operational, could you give me a hand?
RP/0/RSP0/CPU0:Jul 10 18:37:18.415 : dsc[183]: %LICENSE-ASR9K_LICENSE-2-SAT_NEEDED : 3 Satellite(s) are remotely connected without a valid license / license configuration for A9K-NVSAT5-LIC in violation of the Software Right To Use Agreement. This feature may be disabled by the system without the appropriate license. Contact Cisco to purchase the license immediately to avoid potential service interruption.
RP/0/RSP0/CPU0:router#show license
Wed Jul 10 18:52:59.923 GMT
FeatureID: A9K-NVSAT1-LIC (Slot based, Permanent)
  Total licenses 3
  Available for use         3
  Active                    0
  Store index               1
    Pool: Owner
      Total licenses in pool: 3
      Status: Available     3    Operational:    0
  Total licenses 1
  Available for use         0
  Active                    1
  Store index               2
    Pool: Owner
      Status: Available     0    Operational:    1
      Locations with licenses: (Active/Allocated) [SDR]
              0/0/CPU0        (1/0) [Owner]
RP/0/RSP0/CPU0:router(admin-config)#show run
Wed Jul 10 18:53:37.825 GMT
license A9K-iVRF-LIC
location all
license A9K-NVSAT1-LIC
location 0/RSP0/CPU0
location 0/RSP1/CPU0
location 0/0/CPU0
location 0/1/CPU0
end
Thanks in advance.
Renato Reis
Renato,
this may be a bit hard to fix via the support forums, I think it might be best to open a case with XR TAC for some dedicated assistence.
I see one lic is tied to LC0, which is good, where and how are the other satellites conected with their uplinks?
cheers!
xander
HI Alexander,
Actually the lisence that is applied to L0 is another lisence (
A9K-iVRF-LIC). The uplinks are trough a
A9K-24x10GE-TR LC.
Tks.
Renato
Hello Alexander,
Do you have any idea if the message below is due to the fact that the license is not active? I can't bundle interface from the ASR9000V.
RP/0/RSP0/CPU0:router#conf t
RP/0/RSP0/CPU0:router(config)#interface bundle-ether 60
RP/0/RSP0/CPU0:router(config-if)#exit
RP/0/RSP0/CPU0:router(config)#interface gigabitEthernet 200/0/0/21
RP/0/RSP0/CPU0:router(config-if)#bundle id 60 mode on
RP/0/RSP0/CPU0:router(config)#interface gigabitEthernet 200/0/0/43
RP/0/RSP0/CPU0:router(config)#commit
Sat Jul 13 10:28:24.495 GMT
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/RSP0/CPU0:router(config)#show configuration failed
Sat Jul 13 10:28:32.213 GMT
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface GigabitEthernet200/0/0/21
!!% 'CfgMgr' detected the 'fatal' condition 'This configuration has not been verified and can not be accepted by the system.'
interface GigabitEthernet200/0/0/43
end
Thanks in advance,
Renato
fortunately, if a license is not installed or applied, the functionality is still there. the lic is not hard enforced.
what the issue might be what you're having is that we can only have bundle as link between the 9k and the sat
OR bundles on the sat interfaces (and not between host and sat).
Do you have a bundle configured as ICL ?
xander
Yes, I have 3 bundle congigured as ICL and what I'm trying to do is to configure a bundle with the satellite's interface that will connect another router. Is there any place (documentation) where I can't find that I can't do that?
thanks !
Renato
I guess I already found it, now I need to find a workaround for this.
Restrictions of the Satellite nV System
These are some of the software restrictions of the satellite nV system:
•The inter-chassis link redundancy is supported only through the static EtherChannel, and not through LACP based link bundles. Minimum and maximum link commands are not applicable when ICL is a bundle.
•If a satellite system is operating in redundant ICL mode, then you cannot configure link bundles of any form (with or without LACP) on the access ports of that same satellite switch.
•If a satellite system is operating in redundant ICL mode, then Ethernet OAM features are not supported on the access ports of that satellite.
•Multi-chassis Link Aggregation is supported if there are two independent Cisco ASR 9000 Series Routers acting as the POA (Point of Attachment), each with its own satellite switch, and the DHD (Dual Homed Device) connecting through each of the satellite switches. However, MC-LAG is not supported with a single satellite switch that connects two separate Cisco ASR 9000 Series Routers through an ICL LAG.
•The Cisco Discovery Protocol (CDP) is not supported on a bundle Inter Chassis Link (ICL) between the Cisco ASR 9000 Series Router and satellite.
•Cisco ASR 903 Router is not supported on RSP2 Route Processor due to the image size.
Link: http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/interfaces/configuration/guide/hc43satl.html#wpxref96483
Tks
Renato
