08-23-2011 10:04 PM
I've installed the Cisco Client many times before on x32 systems but having just installed same on an x64 System (Win-7 Pro) I just noticed the "Set MTU". Client version I am using is 5.0.07.0290.
What is the purpose for this, and what setting should I use?
Ron
08-23-2011 10:54 PM
Here is more explaination on "Set MTU" on VPN Client for your reference:
Basically it is only needed when you are troubleshooting issue with performance as default MTU on internet devices is typically 1500, and if the VPN Client is sending bigger file than 1500, then it would cause fragmentation which could possibly be blocked along the path, and/or taking the server end sometime to reconstruct the fragmented vpn packets.
However, in normal circumstance, the "Set MTU" setting should not be interfere.
08-24-2011 05:59 AM
Thanks Jennifer!
Ron
08-24-2011 06:01 AM
Cheers, pls kindly mark the post as answered so others can learn from your post. Thank you.
