08-24-2011 11:45 AM - edited 03-11-2019 02:16 PM
I have not worked with ASDM in a while. I have a 5510, with asdm-645.bin in the flash. The device runs version 8.4(2). I can download ASDM from the http interface of the firewall from the management interface. But I can not log in. I have used blank username and password, no username and enable password, blank username with enable password and a few other permutations:-). I then tried to connect to the asdm interface from inside also. But I can not connect. Needless to say, I have enabled http, and updated the http access-list. The only logging I have enabled is buffered. Is there any configuration that I am missing? Shall I cut and past the config? Everything is ok on my pc, as I can use the same asdm client to connect to a 5505. Please help.
08-24-2011 11:50 AM
What is the java version you're running on your system? If you're using java 7, this is not supported with ASDM.
Let me know.
Anu
08-24-2011 02:33 PM
What type of authentication are you using? If you want to use a local username and password on the ASA the config will look like this:
username user1 password cisco
aaa authentication http console LOCAL
Hope that helps.
-Mike
08-25-2011 03:15 AM
I did not have the 2nd command you mentioned. I added it, but my issue was something else. I just figured it out. I am behind a proxy server. Once I added the ip address of the http proxy to the http access list with the http command, I am able to log in. Thanks for your responses.
08-25-2011 03:16 AM
I checked on the JAVA version. I am using version 6. I did notice that I get a different error message when I try to connect to the firewall's inside interface with ASDM vs. the management interface. I prefer the management interface.
