"boot system flash" and "boot system flash flash0"
Answered Question
Aug 25th, 2011
I want to set the boot file to a new IOS image. What's the difference between "boot system flash {file}" and "boot system flash flash0:{file}" ?
In my router I have the following:
TNRTAGCS00003#dir flash:
Directory of flash0:/
    1  -rw-    62558836  Jan 14 2010 06:54:34 +00:00  c2900-universalk9-mz.SPA.150-1.M1.bin
    2  -rw-        2903  Jan 14 2010 07:02:10 +00:00  cpconfig-29xx.cfg
    3  -rw-     2915328  Jan 14 2010 07:02:22 +00:00  cpexpress.tar
    4  -rw-        1038  Jan 14 2010 07:02:30 +00:00  home.shtml
    5  -rw-      115712  Jan 14 2010 07:02:38 +00:00  home.tar
    6  -rw-     1697952  Jan 14 2010 07:02:56 +00:00  securedesktop-ios-3.1.1.45-k9.pkg
    7  -rw-      415956  Jan 14 2010 07:03:06 +00:00  sslclient-win-1.1.4.176.pkg
    8  -rw-    64383836  Aug 24 2011 15:49:20 +00:00  c2900-universalk9-mz.SPA.151-1.T2.bin
260153344 bytes total (128045056 bytes free)
Correct Answer by Leo Laohoo about 5 years 8 months ago
If I remembered correctly ISR G2 has two CF slots.  You can use "flash:" or "flash0:" and they are both the same (by default, if you use "flash:" then it means "flash0:").  If your 2nd CF slot is filled then you use "flash1:".
Overall Rating: 5 (2 ratings)
Amit Aneja Thu, 08/25/2011 - 11:03
  • Bronze, 100 points or more
the correct way to set the boot variable is
"boot system flash:c2900-universalk9-mz.SPA.150-1.M1.bin"
The other command that you mentioned doesn't exist
Amit
Wassim Aouadi Fri, 08/26/2011 - 00:32
Amit,
I tried on one router with the command "boot system flash flash0:..." and it worked.
Here's the running-config:
Current configuration : 12792 bytes
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname Router
boot-start-marker
boot system flash flash0:c2900-universalk9-mz.SPA.151-1.T2.bin
boot-end-marker
logging buffered 51200 warnings
Correct Answer
Leo Laohoo Thu, 08/25/2011 - 15:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
muhammad.cis Fri, 12/27/2013 - 22:07
5 stars for Leo
Another irrelevant but noticable thing is that most of Cisco documentation write "boot system" command as:
boot system
e.g:boot system flash:c2900-universalk9-mz.SPA.151-1.T2.bin
ref:https://supportforums.cisco.com/docs/DOC-2571
the syntax mentioned here is like:
boot system flash
e.g:boot system flash flash0:c2900-universalk9-mz.SPA.151-1.T2.bin
I have checked, both syntax are working equally for me.
Leo Laohoo Sat, 12/28/2013 - 01:12
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings, Muhammad.
Related Content
