Please share your medianet information needs.
Answered Question
Aug 25th, 2011
Are you deploying a medianet? Please share any of your information needs for deploying medianet-based technologies and solutions here. Also share any comments you have on the Medianet Knowledge Base Portal.
Correct Answer by Chris Swinney about 1 month 2 days ago
Hi clavoy,
I am having issue accessing any of the content from the Base Portal - links are not functioning.
Chris
Average Rating: 5 (1 ratings)
dipsark Tue, 09/20/2011 - 20:39
Hi Clavoy,
    I am new to Medianet, just started to learn about it this week.
It will be really helpful, if you clarify the following:
Assume the following set of Medianet enabled Routers   R1->R2-->R3->R4. Each of which are initiator and responder.
Also assume that 10 RTP streams ( different voice and video streams )  are flowing through the Path from R1 to R4.
Will the command: show mediatrace sessions brief  -- show all the 10 RTP streams ? OR it will show only those for which (PROFILE,PATH,FLOW, Source IP/Port, Dest IP/Port) tuples are configured.
That is, out of 10 RTP streams if I have configured 1 pair of  Source-Destination IP/PORT pair, only that will be shown as output of
Dip
mdybka Wed, 09/21/2011 - 08:31
The mediatrace will not display data for all the 10 streams, unless each stream is specified with a configuration.
Mediatrace is used to collect data for specific flows of interest to you. It's purpose is to collect data  for the flows that you specifiy with the tuples configured in mediatrace commands or configurations. Mediatrace is useful for finding the path of a media flow , and eaily also collecting the related statistics for that flow.
You also have available performance monitor which allows you to collect the same flow statistics as mediatrace and have those sent to a Netflow collector. With performance monitor you can classify specific streams for data collection, or very wide classification of streams as interesting.
A sidenote, I notice you mentioned you used the command "show mediatrace sessions brief", which indicates to me that you ran the show command on a responder.
With mediatrace there is a single initiator, and one or more responders. The initiator is the one where the mediatrace command is initiated.... and it is also where the data is collected from the responders and reported ( or exported to NMS).
Correct Answer
Chris Swinney Mon, 03/17/2014 - 14:08
Hi clavoy,
Chris
clavoy Mon, 03/17/2014 - 14:37
Hi Chris,
I just accessed the medianet knowledge base without any problems. Are there specific URLs that are you having trouble accessing? Please send links to the content that you are unable to access and I will investigate.
Charles
Login or Register to take actions
Posted August 25, 2011 at 2:33 PM
Stats:
Replies:4 Avg. Rating:5
Views:2228 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
