JDBC Connection URL to UCCX 8.X Historical DB
Answered Question
Aug 25th, 2011
  • Bronze, 100 points or more
Hi guys,
I'm trying to setup a JDBC connection to the UCCX db_cra database using the uccxhruser. I'm trying the JDBC URL:
jdbc:jtds:sybase://uccxhostname:1504/uccxhostname_uccx
But can't seem to connect. I think I have the DB name bit wrong. Anyone else setup a connection that can advise what they used?
Cheers,
Nathan
Correct Answer by Aaron Harrison about 5 years 8 months ago
It's Informix... assuming you have the informix JDBC drivers set up:
jdbc:informix-sqli://uccxhostname:1504/db_cra:INFORMIXSERVER=uccxhostname_uccx
Aaron
Please rate helpful posts..
Overall Rating: 5 (3 ratings)
Nathan Luk Sun, 08/28/2011 - 21:20
Hi Shalu,
Thanks for that but I'm trying to connect to the UCCX sybase historical reporting database not an external SQL server as per that post. Do you have what the connection URL should look like for this?
Cheers,
Nathan
Correct Answer
Aaron Harrison Mon, 08/29/2011 - 04:53
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
Nathan Luk Mon, 08/29/2011 - 05:28
Ahhh right. Wrong type. That worked a treat thanks for that!
Paul Woelfel Wed, 03/28/2012 - 09:15
I've tried to connect to the Historical DB of UCCX 8.5, but I'm getting an exception "No connect permission" if I try to login with the os admin.
Caused by: java.sql.SQLException: No connect permission.      at com.informix.jdbc.IfxSqli.a(IfxSqli.java:3609)      at com.informix.jdbc.IfxSqli.E(IfxSqli.java:3934)
If I use a normal Administrator account, I get an "Incorrect password or username" exception:
Caused by: java.sql.SQLException: Incorrect password or user com.informix.asf.IfxASFRemoteException: username is not known on the database server.      at com.informix.jdbc.IfxSqliConnect.(IfxSqliConnect.java:1205)
Which user could be used to connect to the database?
anchoudh Wed, 03/28/2012 - 09:24
  • Red, 2250 points or more
In  regards to the historical user queries in 8.x the user ID is  "uccxhruser" and the password of this user can be changed through UCCX  administrator - tools - paswword managent page.
Section "Creating a System DSN for Wallboard" also provides some pointers on how to create a DSN connection to UCCX database
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_0/configuration/guide/uccx801ag.pdf
Hope this helps.
Anand
anchoudh Wed, 03/28/2012 - 19:30
Hi Paul,
Glad to know that its working :-).
Please don't forget to rate the helpful posts, by clicking on the stars below the right answers.
Anand
