APs not Join WiSM
Hello, I am Claudio
I have problems with register the APs in the module WiSM, the AP join statistics is null.
The IPs from APs are local DHCP in the module.
The softtware version in the WiSM is 7.0.116. The APs are 1140. The IOS version on the Cat6500 is 12.2.33SXI4a.
Some of you had a similar problem.
Thanks, best regards
Overall Rating: 5 (2 ratings)
Surendra BG Fri, 08/26/2011 - 08:04
  • Cisco Employee,
are the APs getting the IP address from the same subnet as that of the management int of the WLC is it??
Surendra
Surendra BG Fri, 08/26/2011 - 08:42
  • Cisco Employee,
This does not work.. The APs wil get an IP only if the AP is in the same subnet as that of management interface.. Even the IP helper address will not help..
Surendra
Surendra BG Fri, 08/26/2011 - 08:59
  • Cisco Employee,
Yes this doesnot work...
Surendra
I'm confused!
I believe in something we are not getting it.
this is the topology....
and this is the DHCP leases...
(WiSM-slot2-1) >(WiSM-slot2-1) >show dhcp leases
        MAC                IP         Lease Time Remaining
e8:b7:48:d6:e6:9d    172.23.24.56    23 hours 59 minutes 24 seconds
e8:b7:48:f5:35:46    172.23.24.57    23 hours 59 minutes 22 seconds
e8:b7:48:2c:64:1c    172.23.24.58    23 hours 59 minutes 17 seconds
00:07:7d:2d:69:e5    172.23.24.59    23 hours 59 minutes 13 seconds
e8:b7:48:f5:1f:b4    172.23.24.60    23 hours 59 minutes 23 seconds
00:07:7d:13:06:eb    172.23.24.61    23 hours 59 minutes 29 seconds
e8:b7:48:f5:35:48    172.23.24.63    23 hours 59 minutes 42 seconds
  (WiSM-slot2-1) >
George Stefanick Fri, 08/26/2011 - 09:45
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
We are talking about access points not joining the WLC, correct ?
1) Do you have DHCP option 43 set up ?
2) Do you have DNS set up to resolve CISCO-CAPWAP CONTROLLER
3) You dont have it in the same broadcast domain. So the anwser is NO...
So do you have 1 or 2 set up ?
George Stefanick Fri, 08/26/2011 - 09:07
That would work if you were doing IP FOWRADING on the router. The router will take the AP broadcast and send it to the WLC. Check your router see if you have a IP Forward rule set up on your other deployment.
Surendra BG Fri, 08/26/2011 - 09:11
  • Cisco Employee,
WOW!! i dint know this.. 5+ , worked on a case for hours and it just dint work!! thats y good to be a all round network engineer!!
Surendra
George Stefanick Fri, 08/26/2011 - 09:19
WOW, back at ya!
I was able to finally give back to you for once!
Yup, you add a IP helper of the WLC managment address and you do a IP FORWARD on the router with UDP 5246 and the router will send the request to the WLC (and the other ip helpers as well).
Works great when you dont control DHCP (option 43) or DNS servers.
Works great ... I just used it on a big customer a few weeks ago. After I set it up and get the APs to join I take it back off ...
George Stefanick Fri, 08/26/2011 - 09:57
Understood. Next step...
Do you have 1 or 2 set up from my previuos post ?
Get an IP is a totally different process from the AP joining the WLC.
4) None of te above....
I have internal DHCP in the WiSM....
(WiSM-slot2-1) >show dhcp summary
  Scope Name                   Enabled          Address Range
APS_AVARAS                       Yes      172.23.24.50 -> 172.23.24.200
e8:b7:48:d6:e6:9d    172.23.24.56    23 hours 59 minutes 29 seconds
e8:b7:48:f5:35:46    172.23.24.57    23 hours 59 minutes 28 seconds
e8:b7:48:2c:64:1c    172.23.24.58    23 hours 59 minutes 23 seconds
00:07:7d:2d:69:e5    172.23.24.59    23 hours 59 minutes 19 seconds
e8:b7:48:f5:1f:b4    172.23.24.60    23 hours 59 minutes 29 seconds
00:07:7d:13:06:eb    172.23.24.61    23 hours 59 minutes 35 seconds
e8:b7:48:f5:35:48    172.23.24.63    23 hours 59 minutes 48 seconds
(WiSM-slot2-1) >show dhcp detailed APS_AVARAS
Scope: APS_AVARAS
Enabled.......................................... Yes
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 172.23.24.50
Pool End......................................... 172.23.24.200
Network.......................................... 172.23.24.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 172.23.24.1  0.0.0.0  0.0.0.0
DNS Domain.......................................
DNS.............................................. 0.0.0.0  0.0.0.0  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
(WiSM-slot2-1) >
George Stefanick Fri, 08/26/2011 - 10:58
Ok all good stuff.
Correct your AP is getting an IP address. However, you need to set up DHCP option 43, DNS, IP FORWARD, or put the AP on the same broadcast domain as the WLC. Or manual prime. These "methods" are how the access points finds and joins the WLC.
Here is an exmaple of option 43
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00808714fe.shtml
So you need to understand what each one does and what makes the most sense in your enviroment to use.
Again, just becuase the AP as an IP address. Does not mean it joined the WLC.
Does this help or are you still confused ?
George Stefanick Fri, 08/26/2011 - 12:06
Option 43 is not set by default. If you are using option 43, it sounds like its not working propertly. Post your option 43 config of your router so we can take a peek.
You can also console into a AP. You can see what the ap is telling us ...
George Stefanick Sun, 08/28/2011 - 10:38
again, i think you need to console into the AP. You also need to read that link to make sure you have your option 43 is configured proprtly. Its sounds like the ap isnt joing the controller.
Leo Laohoo Sun, 08/28/2011 - 15:03
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Are you sure the APs are running LWAP/CAPWAP image?  Please post the output to the command "sh version" please.
Console into the AP and enter the enable command "lwapp ap controller ip address ".  If this command allows your AP to join the controller then you need to configure DNS, Option 43 as what George and Surendra has recommended.
The option 43 is configured, and APs is configured by console port (lwapp ap controller ip address
Now the log is...
*osapi_ping_rx: Aug 29 18:42:20.000: %OSAPI-3-TASK_SET_TICKLE: osapi_task.c:3886  Task osapi_ping_rx requesting 1 second timer. Minimum is 20.Setting to 20.
*emWeb: Aug 29 18:35:41.654: %SYSTEM-3-NOTIFY_SAVE_FAIL: nvstore.c:167 Failed to save data for a Non-volatile component. Registrar ID: 42.
*nim_t: Aug 29 18:32:30.548: %SIM-3-PORT_UP: sim.c:9943 Physical port 1 is up!.
*nim_t: Aug 29 18:32:27.775: %SIM-3-PORT_DOWN: sim.c:9946 Physical port 1 is down!.
*nim_t: Aug 29 18:32:26.769: %SIM-3-PORT_UP: sim.c:9943 Physical port 1 is up!.
*fp_main_task: Aug 29 18:26:59.028: %CNFGR-3-INV_COMP_ID: cnfgr.c:2219 Invalid Component Id : Unrecognized (77) in cfgConfiguratorInit.
*fp_main_task: Aug 29 18:26:58.958: %RFID-3-INVALID_NOTIFICATION_INTERVAL: rfid_cfg.c:419 Illegal rfid rssi notification interval value 0-- defaulting.
*fp_main_task: Aug 29 18:26:58.948: %LOG-3-Q_IND: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Aug 29 18:26:58.733: %RRM-3-RRM_LOGMSG: rrmCfg.c:1501 RRM LOG: Airewave Director: Configuration has been sanitized -- save configuration to commit
*fp_main_task: Aug 29 18:26:43.585: %MM-3-MEMBER_ADD_FAILED: mm_dir.c:909 Could not add Mobility Member. Reason: IP already assigned, Member-Count:1,MAC: 00:00:00:00:00:00, IP: 0.0.0.0
*fp_main_task: Aug 29 18:26:43.377: %DTL-3-DSNET_CONF_FAILED: dtl_ds.c:424 Unable to set symmetric mobility tunneling to disabled on Distribution Service interface.
*fp_main_task: Aug 29 18:26:43.364: %SYSTEM-3-PASSWD_STORE_INTEGRITY_FAILED: passwd_store.c:470 Cannot retrieve secret from store -- integrity check failed.
*fp_main_task: Aug 29 18:26:33.393: %CNFGR-3-INV_COMP_ID: cnfgr.c:2219 Invalid Component Id : Unrecognized (36) in cfgConfiguratorInit.
*mfpKeyRefreshTask: Aug 29 18:26:33.392: %SSHPM-3-NOT_INIT: bsnrandom.c:619 Random context not initialized
Leo Laohoo Mon, 08/29/2011 - 15:11
  • Hall of Fame,
    2017 LAN, Wireless
Here's a stupid question:  Can the WAP ping the management IP address of the WiSM?
Dont worry...
Yes.
(Cisco Controller) >show dhcp summary
APs                              Yes      172.23.24.100 -> 172.23.24.150
(Cisco Controller) >show dhcp leases
e8:b7:48:f5:35:46    172.23.24.100    23 hours 59 minutes 39 seconds
e8:b7:48:d6:e6:9d    172.23.24.101    23 hours 59 minutes 40 seconds
00:07:7d:13:06:eb    172.23.24.102    23 hours 59 minutes 41 seconds
00:07:7d:2d:69:e5    172.23.24.103    23 hours 59 minutes 7 seconds
e8:b7:48:2c:64:1c    172.23.24.104    23 hours 59 minutes 11 seconds
e8:b7:48:f5:1f:b4    172.23.24.105    23 hours 59 minutes 18 seconds
(Cisco Controller) >ping 172.23.24.100
Send count=3, Receive count=3 from 172.23.24.100
Leo Laohoo Tue, 08/30/2011 - 16:16
  • Hall of Fame,
    2017 LAN, Wireless
Can the wireless access point (WAP) ping the management IP address of the WiSM?
daviwatk Tue, 08/30/2011 - 20:03
  • Bronze, 100 points or more
You have stated on several occasions that the DHCP pool has been configured with Option 43, but you have not posted the requested output of this configuration.  Please provide the output of this command as well as the IP address of the management interface so we can verify the hex value, if applicable, is configure properly.
If you do not want to provide this information, you can perform the following debug from the AP's console
#debug dhcp detail
You will see whether or not the "Option 43" information is received, as well as a message showing the deciphered decimal IP that the AP is trying to use to send a join request to.  I would perform this debug at the AP's console as well as the following from the WLC CLI to see if any joins are arriving at the controller:
#debug client
Perform a reload on the AP to see if we see the disovery/join traffic to the controller; post the outputs requested to your reply and we can examine what is happening.
If you are not seeing any join requests for this AP at the WLC then the AP is not communicating to the WLC either because option 43 is incorrect or the AP is in another vlan than the management interface with no other disvoery mechanisms in place.
For reference, the following link explains a light weight APs registration process to a WLC; good info, including Option 43, and other discovery mechanisms, as well as the APs "preference" for joining discovered vs configured WLCs, etc.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
The option 43 is......
ip dhcp pool APs
network 172.23.24.0 255.255.255.0
default-router 172.23.24.1
option 43 hex f108ac140194ac140196
The problem is not the option 43, the problem is between the module WiSM and SUP720.
I Replace WiSM for a WLC4402 and APs were recorded without problems
debug WiSM.....
URA_NUNOA_SW_6500_CLH#
Aug 31 16:27:20.818: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd2f.2d22 for slot/port 2/1
Aug 31 16:27:20.822: WiSM-Evt:dman_reg_arp_added: cntrl 2/1 got an ip 172.20.1.178 68ef.bd2f.2d22/68ef.bd2f.2d                            22
Aug 31 16:27:20.822: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd30.58e2 for slot/port 2/2
Aug 31 16:27:20.822: WiSM-Evt:dman_reg_arp_added: cntrl 2/2 got an ip 172.20.1.179 68ef.bd30.58e2/68ef.bd30.58                            e2
Aug 31 16:27:35.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/1
Aug 31 16:27:35.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/2
Aug 31 16:27:55.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/1
Aug 31 16:27:55.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/2
Aug 31 16:28:00.822: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd30.58e2 for slot/port 2/2
Aug 31 16:28:00.822: WiSM-Evt:dman_reg_arp_added: cntrl 2/2 got an ip 172.20.1.179 68ef.bd30.58e2/68ef.bd30.58                            e2
Aug 31 16:28:00.822: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd2f.2d22 for slot/port 2/1
Aug 31 16:28:00.822: WiSM-Evt:dman_reg_arp_added: cntrl 2/1 got an ip 172.20.1.178 68ef.bd2f.2d22/68ef.bd2f.2d                            22
Aug 31 16:28:15.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/1
Aug 31 16:28:15.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/2
Aug 31 16:28:35.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/1
Aug 31 16:28:35.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/2
Aug 31 16:28:40.818: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd2f.2d22 for slot/port 2/1
Aug 31 16:28:40.818: WiSM-Evt:dman_reg_arp_added: cntrl 2/1 got an ip 172.20.1.178 68ef.bd2f.2d22/68ef.bd2f.2d22
Aug 31 16:28:40.822: WiSM-Evt:dman_cntrl_db_search_by_mac: Found mac 68ef.bd30.58e2 for slot/port 2/2
Aug 31 16:28:40.822: WiSM-Evt:dman_reg_arp_added: cntrl 2/2 got an ip 172.20.1.179 68ef.bd30.58e2/68ef.bd30.58e2
Aug 31 16:28:55.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/1
Aug 31 16:28:55.822: WiSM-Evt:dman_proc_keepalive_tmr_handler: keepalive timer expired for 2/2
daviwatk Wed, 08/31/2011 - 16:15
You are now describing a new problem (ie. a bigger problem, although this is most likely leading to the AP join failure symptoms).  Can you verify the following for your WiSM module.  This information is coming from the WiSM config and troubleshooting guide.
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_tech_note09186a00808330a9.shtml
Is the wism showing "Oper-Up" for both WLCs on this WiSM?
#sh wism status
Do you have your etherchannel load balancing configured properly for: src-dst-ip ?
#show etherchannel load balance
Are you etherchannel interfaces up and permitting traffic?
#show etherchannel summary
Also, form the WLC logs above
Explanation    The system failed an integrity check. The secret might have been compromised.
Recommended Action    Reconfigure the secret for security reasons.
You might want to recreate your enable secret; I don't think this is applicable to your problem but should be addressed.
daviwatk Wed, 08/31/2011 - 19:04
Also, as Surendra has pointed out, you must be in the management interface's network if you wish for the LAP to join the WLC via its internal DHCP because, while it is addressed, it must still "discover" the WLC via a L2 broadcast.  In theory your ip helper should forward the L2 broadcast from the AP on to the WLC's mgmt interface.  Is your WLC allowing L2 discovery? Are you forwarding the proper traffic? "(config)ip forward-protocol udp 12223", if not, you must have a layer 3 discovery mechanism as well: DNS, Option 43.
LAP registration to WLC, See section 6 "Use IP helper address on the Router" from this anchored link.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml#topic2
Remember, you must provide alternate discovery as some CAPWAP only devices, 1260, 3500 would not support a L2 discovery
"If" you insist on offering DHCP please keep this in mind...
Taken from WLC FAQ http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00808b4c61.shtml
"The internal server provides DHCP addresses to wireless clients, LAPs, appliance-mode APs on the management interface, and DHCP requests that are relayed from LAPs. WLCs never offer addresses to devices upstream in the wired network. DHCP option 43 is not supported on the internal server, so the AP must use an alternative method to locate the management interface IP address of the controller, such as local subnet broadcast, DNS, Priming, or Over-the-air discovery."
1. I would suggest that you use another device as your DHCP server if feasible and configure Option 43 if desired.
     a. I would also recommend DNS as a good "set it and forget it" discovery mechanism. "CISCO-CAPWAP-CONTROLLER.your.domain" should resolve to your MGMT interface.
2. If your APs are "not" on the same VLAN as the mgmt interface and you really want internal DHCP on the WLC, you must use an alternate discovery method.  Verify your WLC is allowing L2 discovery. For your chosen discovery method of an ip helper, verify you are forwarding udp 12223.
David,
Thanks for you help but the option 43 is not the problem, becouse I replaced the module WiSM for a apliance 4402 and the APs joined succsessfully.
URA_NUNOA_SW_6500_CLH#show wism status
Service Vlan : 209, Service IP Subnet : 172.20.1.177/255.255.255.248
      WLAN
Slot  Controller  Service IP       Management IP    SW Version  Status
2     1           172.20.1.178     172.20.1.148     7.0.116.0   Oper-Up
2     2           172.20.1.179     172.23.24.252    7.0.116.0   Oper-Up
URA_NUNOA_SW_6500_CLH#show etherchannel load-balance
EtherChannel Load-Balancing Configuration:
        src-dst-ip vlan included
        mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
  IPv4: Source XOR Destination IP address
  IPv6: Source XOR Destination IP address
  MPLS: Label or IP
URA_NUNOA_SW_6500_CLH#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 3
Number of aggregators:           3
Group  Port-channel  Protocol    Ports
305    Po305(SU)        -        Gi1/1(P)       Gi1/2(P)       Gi1/3(P)
                                 Gi1/4(P)       Gi1/5(P)       Gi1/6(P)
403    Po403(SU)        -        Gi2/1(P)       Gi2/2(P)       Gi2/3(P)
                                 Gi2/4(P)
404    Po404(SU)        -        Gi2/5(P)       Gi2/6(P)       Gi2/7(P)
                                 Gi2/8(P)
weterry Thu, 09/01/2011 - 06:40
  • Silver, 250 points or more
Are you saying that there are 0 APs able to register to either WLC in the WiSM?  But you can still manage the WLC?
I'm just throwing this out there, based on things I remember from the past, but I'm not sure if its relevant:
I wonder if load-balancing is at fault here?
I remeber awhile ago we had a problem when the switch did "src-dst-ip enhanced".  And the solution to that was later ios allowed a "src-dst-ip eclude vlan" command.....  So the fact that yours is saying vlan included makes me think its like the "enhanced".
If your IOS runnning-config is showing you the interfaces for your WLC, you could try to shut down all but one port and see if everything suddenly starts working, but I'm thinking your IOS might hide all those ports.   Perhaps disabling the port from the WLC itself will have the same effect?
Either way, the idea is still if you have the same problem with a single interface connected (or you can try to change load-balancing to be the "exclude vlan" option, if thats possible).
daviwatk Thu, 09/01/2011 - 09:21
Thats fine.  Your original post stated you are offering DHCP internal to the module, but you also have a DHCP pool defined elsewhere with option 43?
My suggestion was that you do not offer DHCP at the module.  I'm really not sure from what you described whether it is internal or external to the module at this point.  If that pool is external to the module you "should" be fine as you are offering two addresses in option 43, per your hex code: 172.20.1.148 and 172.20.1.150.
Have you performed a debug from the AP to verify it is receiving the Option 43 information correctly?
#debug dhcp detail
You will be able to see what address the AP gets from Option 43.  At that point, the AP should be sending a unicast join to those addreses UDP 12223.  Did you confirm you are permitting traffic for 12223?  Can you ping the mgmt interface of either WLC on the WiSM from the AP?
CORRECTION EDIT:  I have specified LWAPP UDP ports.  This should be CAPWAP UDP ports: 5246 and 5247.  Regardless, we would need to see what the AP console output looks like and verify communication from AP to WLC MGMT.
aous.salloum Tue, 10/18/2011 - 14:44
Dears ,
we have also problem with the WISM in 6513 the Number of Access Points is going up and down on the controllers
and if i try to ping the WISM from the access points vlan am getting so many requests time out
In the core switch we are tagging the native Vlan as you can see below
CORE-SWITCH2#sh run | i tag
vlan dot1q tag native
and we don't have the command wism module 9 controller 1 native-vlan X because the native vlan is tagged
could this be the reason ? that its mandatory that the native VLAN is not tagged for the Cisco WISM configuration
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
