the correct way...
Answered Question
Aug 26th, 2011
Hello guys,
I have the next situation, 9 LAPs 1142N, i wish to convert them to autonomous, it seems that there is a 2 ways, with a simple copy tftp flash: commands and force them to charge the IOS.default  image(holding the mode button), what is the correct way??
I used the first one (copy tftp flash and etc commands) decompressing the winrar file downloaded (c1140-k9w7-tar.124-25d.JA1) and just selecting the .JA file inside, then using the boot system command, but when a try to use the browser appears with out menus! buttons and etc options!, I supose that I need to charge ALL winrar file, but how? some suggestion??
Sorry 4 my English hehehe...
Correct Answer by daviwatk about 5 years 10 months ago
OK, it looks like you are trying a couple of things simultaneously.  You have renamed the image to .default (c1140-k9w7-tar.default) in one instance (to use the mode button).  In another, you have extracted the archive before loading.  The AP trys to extract the file, therefore when it opens the file ending in .JA1 is is confused-- thus the message %Error opening file...
Lets do this, because it seems clear your TFTP is working.
1. Have the following file in the root directory of your TFTP server: c1140-k9w7-tar.124-25d.JA1.tar  ** do not extract this file **
From the AP, it seems you are already addressed and have forced AP to not reload so lets issue the following command...
2. #archive download-sw /f /o tftp:///c1140-k9w7-tar.124-25d.JA1.tar
AP should then be able to "open" the file and with the archive command given above the AP will have extracted the image and overwritten as the boot image and then reload your AP.
Give that a shot and tell us what you find
Overall Rating: 5 (1 ratings)
Roman Rodichev Sat, 08/27/2011 - 04:55
  • Gold, 750 points or more
use the second method with mode button. the first method is meant to be used from the wlc controller
IngGerardo013 Sat, 08/27/2011 - 08:20
This is the image with the error, I have connected a direct utp cable between AP and PC, no firewall and no antivirus
Some sugestion?
George Stefanick Sun, 08/28/2011 - 09:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
Did you put your PC NIC card  on the 10.0.0.x network? The AP takes 10.0.0.1 so your PC with the TFTP should be 10.0.0.2 or something higher ..
Did you do that ?
nikhilcherian Sun, 08/28/2011 - 21:12
  • Bronze, 100 points or more
Have you tried this command
archive tar /xtract tftp:///filename.tar flash:
NikhiL
IngGerardo013 Mon, 08/29/2011 - 08:21
HERE, I SHOW THAT I CAN COPY FILES FROM MY LAP-TOP TO THE AP:
4 bytes copied in 0.042 secs (95 bytes/sec)
HERE, I EXECUTE THE RECOMMENDED COMMAND:
AP44d3.ca19.81a6#$ftp://15.10.10.184/c1140-k9w7-mx.124-25d.JA1.rar flash:
Loading c1140-k9w7-mx.124-25d.JA1.rar from 15.10.10.184 (via GigabitEthernet0):
%Tar checksum error in fd 0 --------------------------------------- "THIS IS THE ERROR"
AP44d3.ca19.81a6#sh flash:
Directory of flash:/
    2  -rwx        3566   Mar 1 2002 00:29:43 +00:00  private-config
    3  -rwx           4   Mar 1 2002 00:29:00 +00:00  test.txt
    4  -rwx         150   Mar 1 2002 00:14:33 +00:00  event.log
    5  -rwx     4791401   Mar 1 2002 00:52:40 +00:00  c1140-k9w7-mx.124-25d.JA1
    6  -rwx        1048   Mar 1 2002 00:29:44 +00:00  private-multiple-fs
    7  drwx         128   Mar 1 2002 00:02:01 +00:00  c1140-rcvk9w8-mx
   10  -rwx       17468   Mar 1 2002 00:29:43 +00:00  config.txt
   11  -rwx         217   Mar 1 2002 00:53:22 +00:00  env_vars
HERE, I SHOW THAT THERE IS ENOUGH SPACE(THE COMPRESED IMAGE SIZE 5MB):
32126976 bytes total (25048064 bytes free)
AP44d3.ca19.81a6#
nikhilcherian Mon, 08/29/2011 - 09:46
If you have downloded the image from Cisco.com, can you try to download the image again from cisco site and extract the file. Just want to make sure the tar file is not corrupt
NikhiL
pcroak Mon, 08/29/2011 - 21:29
  • Cisco Employee,
The alternative method to using the MODE button is as follows:
1. Download the image from cisco.com -- do not modify the file archive.
2. Issue the following commands on the lightweight AP:
debug capwap console cli
archive download-sw /force /over tftp:///
This will automatically download and extract the tar image, and remove the lightweight image (and reload the AP when finished). Please let me know if this works for you!
-Patrick Croak
Wireless TAC
pcroak Wed, 08/31/2011 - 14:58
  • Cisco Employee,
that looks like the file was not found -- we need to remember that the image archive has a file extension of .tar (even if extensions are hidden)
so the command should be:
archive download-sw /force /over tftp://10.0.0.2/c1140-k9w7-tar.124-25d.JA1.tar
Please try this one more time and let me know!
-Pat
Leo Laohoo Wed, 08/31/2011 - 17:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
1.  When you performed the "mode" button proceedure, what is the IP address and subnet mask of the TFTP server?
2.  How is your AP connected to your TFTP server?
3.  What application is your TFTP server?
IngGerardo013 Wed, 08/31/2011 - 21:54
1.- 10.0.0.2 /24 bits
2.- using a small switch
3.- TFTP Server Manager version 4.0
Correct Answer
daviwatk Wed, 08/31/2011 - 18:24
IngGerardo013 Thu, 09/01/2011 - 09:01
I can not overwrite the copressed files (winrar archive) using the command archive.... because I could not copy that files to the LAP´s flash.. That is the first problem... trying to use the button mode procedure... it seems that can not find my lap top because I hold a constant ping to 10.0.0.2 (my tftp server) and not responds when I hold the button after the turn on the ap:
this is the error message:
examining image...
%Error opening tftp://255.255.255.255/c1140-k9w7-tar.default (invalid argument)
ap:
daviwatk Thu, 09/01/2011 - 09:27
So.. Did you do what I said in the post above?  Now you're talking about mode button again.  Can you perform the archive command I mentioned above for the non-extracted raw image file you downloaded?
Bottom line, if you feel the AP cannot "find" or communicate via TFTP to your client, this is not the APs problem.  Try another Client all together; perhaps it is blocking TFTP communication via software security, firewall, etc.
I'm not sure if you performed the steps above that I mentioned.
IngGerardo013 Thu, 09/01/2011 - 12:08
David Watkings,
Your answer was tried in the same discution, but it did not work,
Today I tried again 5 times using a new downloaded image from cisco.. I wanted to Imp Pt and show you, why 5 times? well because when I configured the ip on int giga0, after some seconds LAP erease my ip configurated, I dont know why
but in the 5 time finally charged the compressed files!,
This is part of a project that originaly has been planed to use WLC, client at the last minute refuse the WLC, but the order purchase was made, he told us that in a future he will migrate to a WLC, I hope do not have the same problems to re-convert the now autonomus AP to LAP.
I have to give thanks to all people that dynamically participated in this discution,
If someone could explain me why the LAP do not held the ip configurated, I would be great!
Now I am going to convert 8 LAP more.. I hope no have the same problems using the new downloaded the tar file..
thanks a lot, and saludations
daviwatk Thu, 09/01/2011 - 12:19
Have you tried this with another client yet?  It looks like the problem is "opening" the file.  Even though the AP can ping your laptops IP, it doesn't seem like it can initate a TFTP session, for reasons I mentioned prior.
The reason your AP is getting a new address is because it is lightweight.  It is attempting to discover the WLC and once it exhausts all it's methods, it re-DHCPs and starts over; this will happen over and over every 1-2 minutes.  I was under the impression you have already overcome this as this could be interrupting your TFTP transfers.
Do this before attempting the TFTP transfer from the AP CLI.  This allows you to configure the interface as well as prevent the LAP from re-loading.  Dont try and autofill these commands because they are hidden, just type them in as they appear below.
#debug capwap console cli
#debug capwap client no-reload
#config t
#(config) int gig 0 (or whatever your ethernet interface is)
#(config-if) no ip address dhcp
#(config-if) ip address
#end
Now your AP should have a static address and not be reloading.  I have seen these be tempermental sometimes, so once you get the address set, don't waste any time issuing the TFTP command to kick off the transfer.
IngGerardo013 Thu, 09/01/2011 - 14:36
This was the result:
AP003a.99eb.5d12#debug capwap console cli
CAPWAP console CLI allow/disallow debugging is on -----THIS COMMAND WAS EXECUTED SOME TIMES TO TRY RECONOZISE THE NEXT COMMAND----
AP003a.99eb.5d12#debug capwap client no-reload
% Invalid input detected at '^' marker. --.COMMAND WAS NOT ACCEPTED WRITTING DOWN COMPLETE---
AP003a.99eb.5d12#
I could not to avoid that LAP erease the IP configurated..but the important was to charge the tar file..
daviwatk Thu, 09/01/2011 - 15:03
So you got this AP converted properly?  I'm extremely curious "what" fixed your problem.  Was it the archive command I provided?
IngGerardo013 Thu, 09/01/2011 - 15:46
Yeap, after load the tar file, I could access to the web interface with out any problems due to all files are in the flash,
I commented that I download the image again, because I "played" many times with the first downloaded image.. extracting the content, changing the extention etc etc and maybe that operations corrupted the files...
this was the solution:
int gi0
ip add 10.0.0.2 255.255.255.0
salutations
