Mac Lion and Cisco VPN client problems
Aug 26th, 2011
I just installed Lion 10.7 on my iMac and can no longer use the downloaded Cisco VPN client to connect to Microsoft Remote Desktop and access the PC in my company's office. When I try to launch the VPN client I get Error 51. I used to be able to enter a command in the Terminal as a workaround to use the VPN client when that happened, but that no longer works. I have tried booting into 32-bit mode; doesn't work. I tried to use the Cisco client built into Lion using settings provided by my company. When I try to connect I get the following message: "The negotiation with the VPN server failed. Verify the server address and try reconnecting."
I have searched the web looking for a solution. My company's tech department is stumped; the Apple Geniuses haven't been able to help. Does anyone have any ideas how I can use either the downloaded Cisco VPN client or the client built into Lion?
rohaverm Fri, 08/26/2011 - 22:26
Here is the link which you can use to configure the inbuilt VPN client in MAC Lion.
http://glazenbakje.wordpress.com/2011/07/28/how-to-create-a-cisco-vpn-connection-in-apple-mac-os-x-lion/
Make sure you configure the attributes correctly.
Secondly the inbuilt VPN client code of Lion is made in collaboration with Cisco so there will not be any issues of compatibility.
Cheers,
Rohan
Irakaplan Sat, 08/27/2011 - 05:26
Thank you for your reply Rohan. I actually used this site to set up the built-in VPN. My IT department gave me the settings and checked them afterward. But when I try to connect I get the aforementioned error message. That why I am so puzzled. Everything seems correct, yet it doesn't work. I would welcome any other suggestions.
rohaverm Sat, 08/27/2011 - 12:10
Try connecting using  AnyConnect 3.0.3050:
This is the latest version in the Anyconnect family and supports Lion 10.7. Here is the release note which you can refer before installing,
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect30/release/notes/anyconnect30rn.html#wp1364175
Make sure to uninstall all previous versions and temporary files before installing this.
rnbutturini Sun, 08/28/2011 - 17:47
Agreed with the solution above. We have deployed this to all our Lion machines that could not install the 2050 build and this worked great.
Irakaplan Sun, 08/28/2011 - 17:57
I am just an employee and not an administrator or an IT guy, so apparently I can't download AnyConnect from the Cisco site. I asked my IT department last week if I could try it, and they said no - that we only use the Cisco VPN client they provided for me (which isn't working for me). I will approach them again, because this could be the solution. Thanks.
jnmacdonald Tue, 10/25/2011 - 13:08
Keep getting the following error with AnyConnect on Mac Lion:
The VPN agent service is not responding.  Please restart this application after a minute.
Anybody know how to fix this?
rohaverm Wed, 10/26/2011 - 00:25
Hi Ira,
Problem with Cisco VPN client on MAC Lion is a known issue. If you cannot use the Anyconnect client then go ahead to use the inbuilt VPN client feature of the LION which is also developed in co-ordination of the CISCO. Here is the link which you can refer
http://www.vpnaccounts.com/mac-os-x-10-6.html, this configuration is valid for LION 10.7 too.
Rohan
chucktranhpb Sun, 10/30/2011 - 07:41
That error you are seeing when attempting to connect with the built-in VPN client is caused by not entering a username before hitting the connect button. Try typing something in the username box and see if that allows you to connect.
