How to access personal directory without userid and pin CUCM 7.1
Foo Chuan Soon
Is there anyway we can disable the userid and pin on the personal directory, as it is too trouble to use phone button key in userid and pin.
Payal Bhaduri
Unfortunately, there is no way to disable prompting for User id and Pin. A workaround is
the to configure a phone service with same functionality as Personal Directory, and with
that you can preconfigure Userid and Pin.
Steps involved:
1. Create a phone service named PAB
2. Use the following URL
http://server-name-or-ipaddr:8080/ccmpd/login.do?name=#DEVICENAME#&service=​pab​
3. Add the following service parameters (no default value)
                               - name
                               - pin
                               - userid
4. Go to the phone you would like to add the service to.
5. Go to related links -> Subscribe/Unsubscribe Services
6. Select the PAB service you created -> next
7. In the name field enter the device description SEP then MAC (ex. SEP003123456789)
8. In the pin field enter the users pin
9. In the userid field enter users Id
10. Click subscribe
11. Click Save
12. Reset the phone
Payal Bhaduri
shalushar
Level 7
Level 7
In addition to what Payal has suggested, for Personal directory and fast address book please find below the urls
For Personal Directory
http://server-name-or-ipaddr:8080/ccmpd/login.do?name=#DEVICENAME#&service=​pd​
For Fast Dials
http://server-name-or-ipaddr:8080/ccmpd/login.do?name=#DEVICENAME#&service=​fd​
Hope this helps.
Tx,
Shalu
