ESXi license install on UCS B200M2 fail
Answered Question
Aug 31st, 2011
I tried to keyed in the VMware license into ESXi 4.1 from vSphere client and all the 16 keys were always prompted failed with message "not valid on this product.
I installed using the Cisco ISO image "VMware-VMvisor-Installer-4.1.0-260247_Cisco.iso" on the B200M2 server. The license product code is VMW-VS-ENTP-1A=, the license key format is XXXXX-XXXXX-XXXXX-XXXXX-XXXXX.
Has anyone registered the ESXi license on UCS B series and able to enlighten me? Thanks
Correct Answer by mipetrin about 5 years 8 months ago
Hi Robin
Assuming your XXXX is referring to Cisco PAKs, the Cisco PAKs that you received need to be redeemed via the VMware OEM Specific portal. You will then receive emails from VMware containing the VMware license. It is these licenses received from VMware that can then be placed into the VMware license portal so that they can be registered and managed.
The following links explain the entire procedure and the second link contains a video demonstrating the process.
OEM Portal Overview:
http://www.vmware.com/support/licensing/oem-help.html
VMware Partner Activation Codes (PAC) Explained
http://kb.vmware.com/kb/1003303
Hope that helps to clarify things.
Michael
Overall Rating: 5 (1 ratings)
Correct Answer
mipetrin Wed, 08/31/2011 - 22:31
  • Cisco Employee,
Hi Robin
Michael
robin99 Wed, 08/31/2011 - 23:44
Hi Michael, Thanks for your response. I managed to get the real licence registered. Thanks
Related Content
