Packet tracer for ASDM error
richardpekarsky
Everytime I try to use packet tracer I get the following error...
error while forming the xml data
I click OK and there is absolutely no output.  I ahve uninstalled and reinstalled the ASDM and this happens on multiple firewalls.  This does not happen when I access the FW through other systems.  I have searched pretty hard and cannot find anything relating to this error.
6 Replies 6
varrao
Level 10
Level 10
Hi Richard,
what is the version of ASDM and ASA taht you are using.
-Varun
Varun Rao
HI Richard,
Can you also provide an output of "show run interface" from the firewall?? It could be a bug as well.
-Varun
Varun Rao
MDV-ASA-01# sh run int
interface Ethernet0/0
description Internet interface
nameif outside
security-level 0
ip address
interface Ethernet0/1
description CPF-External-Connection
speed 100
duplex full
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/2
nameif inside
security-level 100
ip address Firewall 255.255.0.0
interface Ethernet0/3
description DMZ for wireless guest access
nameif DMZ
security-level 50
ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
I removed the ip addresses
Arvo Bowen
Did anything ever become of this?  Having the same issue...
I would presume that most problems with ASDM are related to some problem with Java , some problem with the actual ASDM software version or simply a problem on the actual host where the ASDM is run on.
The original poster or you didnt mention any software version you are using.
As an alternative you could try out using the "packet-tracer" from the CLI or the ASDMs Tools menu -> Command Line Interface.
The format is very simple
packet-tracer input
packet-tracer input
I personally always use the "packet-tracer" from the CLI of ASA
- Jouni
SOcchiogrosso
Level 4
Level 4
Verify your version of java is compatible
Edit: changed flash to java
Sent from Cisco Technical Support Android App
-- CCNP, CCIP, CCDP, CCNA: Security/Wireless Blog: http://ccie-or-null.net/
