Purge Inactive User from CUCM before Garbage Collector
Answered Question
Sep 1st, 2011
Centralized Call Processing with Multi-site deployment
CUCM Version 7.1.3b
LDAP Integrated
Is there a way to delete a user account from CUCM (LDAP Integrated) before the Garbabge collector runs at 3:15AM?
The users account is inactive in AD, I tried restarting the Cisco DirSync and then LDAP resync but still no luck in removing the users account.
Thanks for looking!
Correct Answer by Joseph Martini about 5 years 5 months ago
No there isn't a way to remove the user earlier, like you found the garbage collector has to remove the now marked inactive user.
Overall Rating: 5 (1 ratings)
Correct Answer
Joseph Martini Fri, 09/02/2011 - 01:03
David Undernehr Fri, 09/02/2011 - 08:15
Thanks for the reply. I pretty much knew that was the case but wanted to confirm it.
Related Content
