Cisco Administrator Desktop - error Directory Synch - does not synch/match
Answered Question
Sep 3rd, 2011
  • Red, 2250 points or more
Hey guys
Does anybody knows how to resolve this problem on UCCX 7.0?
This problem affect all Cisco Agent, Supervisors Desktop application.
Best regards
Daniel
Correct Answer by Brandon Lightle about 5 years 4 months ago
Make sure that you have cleared out any inactive agents (if you have any). I have seen this cause the DIR sync to fail many times.
1) Log into AppAdmin
2) Click on Subsystems > RmCm
3) Click on Resources (on the left colum)
4) You should see a link on the right about 1/4 way down that says 'Inactive Agents'
5) Clear these out
Overall Rating: 5 (1 ratings)
Aaron Harrison Sat, 09/03/2011 - 06:48
  • Community Spotlight Award,
    Member's Choice, May 2015
If you haven't done this already, restart the Desktop Sync service from Control Centre in appadmin. Doing this via AppAdmin shouldn't cause any outages or failovers.
If you have, and it still doesn't sync, you'll need to start looking at the log files...
Aaron
Please rate helpful posts...
dsobrinho Sat, 09/03/2011 - 08:46
Hi Aaron,
I have done this step, but nothing change same  problem. I collect the code "CDAUI2082 At least one error has occurrred  during the manual synchronization of directory Services"
Recently  the IT team change the Password from CUCM cluster, and after apply new  update of password on Jtapi and rmcm the services are no more available.
I have re-check the synch between CUCM and UCCX and is good.
Only the directory services no more synch correctly.
Best regards,
Daniel
Correct Answer
Brandon Lightle Fri, 01/06/2012 - 07:14
  • Cisco Employee,
5) Clear these out
