Dual stack support
Sep 4th, 2011
dears,
three questions
1) is the 7206VXR support dual stack ipv4 and ipv6?
2) is 7606 with sup720-B SUPPORT DUAL STACK IPV4 AND IPV6?
3) is 6513 with FW and IPD module support dual  stack?
4) is GSR 12410 support dual stack?
thank you in advance
Marcin Latosiewicz Mon, 09/05/2011 - 02:04
Ahmed,
Please be aware that most of those devices do support dual stack. But the exact features and versions is something you will need to discuss with you SE.
Please also be aware thet FWSM in particular is implementing IPv6 in CPU, i.e. will not give you proper throughput and does not integrate well with failover features.
Please reach out to your local SE to discuss what features and versions might be neede.
Marcin
SaeedBakh_2 Mon, 09/05/2011 - 07:54
Hi so what is the modules not support ipv6 bellow also the fwmw will run in transparent mode is there any impact here or limitation. Also what about the IPS
Marcin Latosiewicz Mon, 09/05/2011 - 08:14
Ahmed,
FWSM support for IPv6 is not dependant on mode of operation, to process IPv6 in a stateful way we need to handle traffic in CPU (note that ASA SM should not have this limitation).
Regarding IDSM, I found a quote internally (from Oct 2009, but should be still relevant).
The IDSM-2, AIM-IPS, and NME-IPS are not supported for IPv6 monitoring.
No roadmap yet for this support as far as I am aware.
HTH,
Marcin
