09-05-2011 03:06 AM - edited 03-14-2019 08:29 AM
Is Single Sign on supported for Cisco Agent Desktop? Client currently integrates UC with Active Directory.
If not is this due in a future release?
Thanks in Advance for your help.
09-07-2011 01:10 PM
If your CUCM is integrated with AD for Directory services and authentication the users will user the same username and password that they have in AD to login into CAD/CSD.
Please rate this post if was helpful
Walter Solano
09-07-2011 09:44 PM
Hi Walter,
Thank you for your answer.
What I want to know is If the UCCX 8.5 supports the Single Sign on feature i.e. once you login into UC environment you don't need to provide your credentils(username\passowrd) to loging into any of the client applications like CAD\CSD, CUPC, CCM End User page...etc
Anand
09-08-2011 11:28 AM
Anand
UCCX does not has that feature
