James Hawkins Tue, 09/06/2011 - 12:53
  • Blue, 1500 points or more
Hi Pete,
I am not sure that you will find any up to date Visio stencils for MCS servers.
You could download the HP/IBM server stencils from Visiocafe and maybe ungroup the shape and change the fill colour so that they look like Cisco servers
http://www.visiocafe.com/ibm.htm
PetersonPereira_2 Tue, 09/06/2011 - 23:12
Hi James,
Thank you for your response, would u able to tell me which one in HP/IBM would at least appear to look like the MCS. I'm doing a review for a client and I would want to add a complete layout of their racks to my report.
Cheers/Pete
James Hawkins Wed, 09/07/2011 - 00:02
If you look at the HP and IBM links from the page below then you should be able to see which MCS model maps to whcih HP/IBM server.
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/product_solution_overview_list.html
For example from table 2 of the HP link you can find that:
MCS7845-H2 is a rebadged DL380-G5 Server with 4 drives
MCS7835-H2 is a rebadged DL380-G5 Server with 2 drives
MCS7825-H3 is a rebadged DL320-G5 Server with 2 drives
and so on.
PetersonPereira_2 Tue, 09/06/2011 - 23:09
Thanks Brandon, however that link does not have the stencil for MCS 7800 series...
