9971 Wireless Recording with Built In Bridge?
Sep 6th, 2011
  • Silver, 250 points or more
Has anyone tried to use a wireless 9971 phone and SIP recording to Zoom/etc?  I have a wired 9971 recording fine with Zoom but a wireless 9971 does not record with same phone settings. If I disable wireless on 9971 and plug it in it records fine.
I'm not able to find any cisco docs on wireless versus wired for recording feature.
Overall Rating: 5 (1 ratings)
Joseph Martini Wed, 09/07/2011 - 03:19
  • Cisco Employee,
Interesting, I haven't tried it, I wonder if it's disabled due to the extra traffic that is sent with recording enabled.  I'll try this out when I get to the office and let you know what I find.  There might be a message printed in the phone console logs about recording being disabled when connected wirelessly.
Joseph Martini Thu, 09/08/2011 - 11:55
  • Cisco Employee,
I confirmed that recording does not work if you are using wireless on a 9971.  I'm looking into why this isn't documented if it truely is by design.
joshua.gertig Tue, 12/27/2011 - 11:26
Any updates to this? We're planning on configuring some 9971's for WiFi and would like to know if this is truly a limitation.
Erick Bergquist Tue, 12/27/2011 - 11:32
We have it working, it was a wireless controller issue. We had to disable call admissioin control on the WLC and it works fine and that also cleared up some other 9971 isues we had. Before we disabled the Call Admission Control on the controller, we had set the max # of calls/streams and the max bandwidth values to the max value also and that did not help, until we disabled the call admission control completely.  We only have a dozen or so phones on the wireless so not really a big deal for us at this time having that disabled.
