Installation of CUEACS - Error
Fabien GILLET
I try to install the Cisco Unified Enterprise Attendant Console Server but it's don't work.
I lauch the "CUEACS_Setup.exe" but after some checks i see the error :
I have try some tests like this : http://support.microsoft.com/kb/929991 but the problem still the same.
Thanks in advance for your help.
Regards, Fabien.
Ah - the manual says this:
Windows 2003 Server SP2 running Windows English Regional Settings. Windows 2008 R1 (32 bit) Server is also supported
I suspect that it's failing because of your language settings.
Try switching to English?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
7 Replies 7
Aaron Harrison
What account are you logging in as?
What is the OS?
Aaron
I log with the Administrator account.
I'm under Windows 2008 Server SP2.
I have install the software (.NET Framework...) request by Cisco but it's don't work...
Thanks for your help Aaron.
Is it 32-bit or 64-bit 2008?
Which version of the framework have you installed?
Aaron
I'm in 32-bit version and i have install .NET Framework SP1.
I try to install the CUEAC_SV_8.6.1.9.
Fabien.
Aaron
Hi Aaron,
So i have make a new install on Windows Server 2008 English and the setup works fine.
I have desactivate the User Account Control in Windows 2008 and i have not activate the Remote Access it was activate on the old server. Probably was the problem, i don't know.
Really thanks for your help and i hope this post will be helpful.
Regards.
Fabien.
Good to hear you have it fixed.
Please remember to rate useful responses and mark 'answered' if appropriate.
Aaron
