Nexus 1KV TACACS+ Not Working
1gtopf
I have been trying to get my Nexus 1KV working with AAA/TACACS+ and I'm stumped.
The short version is that I see where the issue is, but can't seem to resolve it.
When I try to log in using TACACS, it fails.  The ACS server reports InvalidPassword.
The CLI on the Nexus shows:
2011 Sep  9 16:37:13 NY_nexus1000v %TACACS-3-TACACS_ERROR_MESSAGE: All servers failed to respond
2011 Sep  9 16:37:14 NY_nexus1000v %AUTHPRIV-3-SYSTEM_MSG: pam_aaa:Authentication failed for user gtopf from 192.168.20.151 - sshd[15675]
2011 Sep  9 16:37:23 NY_nexus1000v %DAEMON-3-SYSTEM_MSG: error: PAM: Authentication failure for illegal user gtopf from 192.168.20.151 - sshd[15672]
And an AAA test from the nexus fails.
I have good connectivity between the two boxes, I can ping, and obviously the failed login showing on ACS shows that it's talking, but it's just not working.
My config is below (omitted ethernet port configs)
!Command: show running-config
!Time: Fri Sep  9 16:45:49 2011
version 4.2(1)SV1(4a)
no feature telnet
feature tacacs+
feature lacp
username admin password 5 $1$Q50UpgN/$4eu39QmZHLTf3FAkwwdOF1  role network-admin
banner motd #Nexus 1000v Switch#
ssh key rsa 2048
ip domain-lookup
ip domain-lookup
ip name-server 192.168.20.10
tacacs-server timeout 30
tacacs-server host 192.168.20.30 key 7 "j3gp0"
aaa group server tacacs+ TacServer
    server 192.168.20.30
    deadtime 15
    use-vrf management
    source-interface mgmt0
hostname NY_nexus1000v
ntp server 192.168.20.10
aaa authentication login default group TacServer
aaa authentication login console group TacServer
aaa authentication login error-enable
tacacs-server directed-request
vrf context management
  ip route 0.0.0.0/0 192.168.240.1
vlan 1,20,40,240
lacp offload
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type ethernet system-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 20,40,240
  channel-group auto mode active
  no shutdown
  system vlan 240
  description "System profile for critical ports"
  state enabled
port-profile type vethernet data20
  vmware port-group
  switchport mode access
  switchport access vlan 20
  no shutdown
  description "Data profile for VM traffic 20 VLAN"
  state enabled
port-profile type vethernet data40
  vmware port-group
  switchport access vlan 40
  no shutdown
  description "Data profile for VM traffic 40 VLAN"
  state enabled
port-profile type vethernet data240
  vmware port-group
  switchport access vlan 240
  no shutdown
  description "Data profile for VM traffic 240 VLAN"
  state enabled
port-profile type vethernet system-upilnk
  description "Uplink profile for VM traffic"
vdc NY_nexus1000v id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 32 maximum 32
  limit-resource u6route-mem minimum 16 maximum 16
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
  inherit port-profile system-uplink
  vem 3
interface port-channel2
  vem 4
interface port-channel3
  vem 5
interface port-channel4
  vem 6
interface mgmt0
  ip address 192.168.240.10/24
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-2
svs-domain
  domain id 500
  control vlan 240
  packet vlan 240
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 192.168.20.127 port 80
  vmware dvs uuid "52 8b 1d 50 44 9d d7 1f-b6 25 76 f1 f7 97 d8 5e" datacenter-name 28th St Datacenter
  max-ports 8192
  connect
vsn type vsg global
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
CARL LINDAHL
Curious. Under
interface mgmt0
Can you add "vrf member management" to the interface mgmt0?
add the following to you config:
aaa authentication login ascii-authentication
hth
FYI...
I was able to get TACACS+ auth working using the commands in the Original Post (without the two additional suggestions) as follows...
1000v# conf t
1000v(config)# feature tacacs+
1000v(config)# tacacs-server host 192.168.1.1 key 0
1000v(config)# aaa group server tacacs+ TacServer
1000v(config-tacacs+)# server 192.168.1.1
1000v(config-tacacs+)# use-vrf management
1000v(config-tacacs+)# source-interface mgmt 0
1000v(config-tacacs+)# aaa authentication login default group TacServer local
1000v(config)# aaa authentication login error-enable
1000v(config)# tacacs-server directed-request
I guess the OP had some other problem (perhaps incorrect shared secret??)
Michael Holder
I had a similiar issue with a Nexus 5020 authenticating our Ciscoworks account and giving the illegal user log message.  Other users were connecting fine.
Debugs showed TACACS failing to resolve the Ciscowrks servers hostname in a reverse lookup.
I removed the ip domain lookup and name-server from the config, and was able to connect.
