09-12-2011 10:15 AM - edited 03-21-2019 04:39 AM
I have this happening on a couple clients. Both are 64bit, the only thing i can think of is both of them had their passwords changed. I have gone back into CCA, CUE, and the CallConnector suite and made sure the passwords are all the same but I still get this error. Any ideas? Should i just delete and recreate the user with the correct password to begin with. Seems like there is some disconnect somewhere, maybe i am missing a password change in some application.
Jeremy Fender
09-13-2011 01:49 AM
Dear Jeremy. I have escalated this issue for a response. Please stay tuned.
Alberto
09-13-2011 06:32 AM
I believe the issue will have fixed itself now that I had to do a factory reset due to database corruption and an old build file. I'll let you know.
Jeremy Fender
PC Net Inc.
Sent from my Verizon Wireless 4GLTE smartphone
09-13-2011 07:44 AM
Hi Jeremy,
Please re-download CME Configuration Data if you have username/password of the phone changed. This will help SCC Server to update the phone info.
We do support Schedule Task that order Configuration Manager to stop/start services, download CME Configuration data, import users/contacts, and compact database at a specific time. Please let us know if you want this to setup.
Also, 1 phone can't allow more than 1 TAPI connection. If the phone is registered to other app, please remove the TAPI connection from that app so that SCC Server can register the phone.
CallConnector Team
