why I m having timeouts on my vpn clients...
Answered Question
Sep 12th, 2011
Hi All
How can I check I have the right vpn time on a VPN client  session on a asa 5510 , and how can I modify it to more time...
Sincerely
Carlos
Correct Answer by Fabio Francisco about 5 years 9 months ago
Hi Carlos,
The logs will tell you everything that you need.
Do you know how to access the logs? on the CLI type show logging on the gui look for logging
Are you also running a syslog server?
Let me know if you need further help.
Cheers,
Fabio
Overall Rating: 5 (1 ratings)
Correct Answer
Fabio Francisco Mon, 09/12/2011 - 16:24
Hi Carlos,
Cheers,
Fabio
juancarlosmartinez Tue, 09/13/2011 - 06:35
Hi Flavio
Thanks for the info  I will try that and if  any questions I contact you thru here
I appriciated  yoiur help
Carlos
