WCCP bouncing every minute
Sep 12th, 2011
We've pair of C7206VXR NPE-G2s that we're trying to upgrade to ASR1004 that talks to pair of WAE7371s. I've attempted twice to upgrade the routers but failed due to "WCCP" bouncing every minute. TAC suggested that I modify the wccp load balacing feature from
"wccp tcp-promiscuous router-list-num 1 hash-source-ip hash-destination-ip" to "wccp tcp-promiscuous router-list-num 1 mask-assign".
But the "WCCP" still bouncing every minute even after the change.
Has anyone experienced same issue ? if so, Could you share your solution if the solution has been found ?
We're running 4.1.5f on WAEs and 15.0(1)S on the ASR1004.
anthony.brewley... Tue, 09/13/2011 - 14:19
I have 2 x ASR 1002 facing 2 x 7341 (not exactly the same, but...)
I'm using the following and it works well:
wccp router-list 1 10.x.x.1 10.x.x.21
wccp tcp-promiscuous mask src-ip-mask 0x300 dst-ip-mask 0x0
wccp version 2
egress-method negotiated-return intercept-method wccp
WAAS s/w is 4.3.3
ASR is asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin
Anthony
