09-14-2011 02:27 AM
I am trying to build som quick snmp-checks from Nagios to the ASR.
I want to be able to monitor the state of the temperature, hd, fan and power. I am really having trouble getting the right data from the box.
Anyone who did this with success?
Andreas
Solved! Go to Solution.
09-14-2011 05:07 AM
Hi Andreas,
I am not sure if the disk usage is available. For the rest you can use "CISCO-ENTITY-SENSOR-MIB" to retrieve sensor entity information.
Below are the OID's you should use:
entSensorValue - 1.3.6.1.4.1.9.9.91.1.1.1.1.4 - This will give you each of the sensor values for (Temp, Voltage, Fan Speed, etc...)
entSensorType - 1.3.6.1.4.1.9.9.91.1.1.1.1.1 - This variable indicates the type of data reported by the entSensorValue.
entPhysicalName - 1.3.6.1.2.1.47.1.1.1.1.7 - This is the textual name of the physical entity your querying so you can match it up with index value from above.
For example:
FAN speed
entPhysicalDescr
root@Slack:~# snmpwalk -v2c -c public obama 1.3.6.1.2.1.47.1.1.1.1.2 | grep -i "fan speed sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.6869781 = STRING: "Fan Speed Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.11741762 = STRING: "Fan Speed Sensor"
entPhysicalName
root@Slack:~# snmpwalk -v2c -c public obama 1.3.6.1.2.1.47.1.1.1.1.7 | grep -i "speed"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.6869781 = STRING: "speed 0/FT1/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.11741762 = STRING: "speed 0/FT1/SP"
Geting Fan Speed
snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.6869781
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.6869781 = INTEGER: 3540
root@Slack:~# snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.11741762
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.11741762 = INTEGER: 3510
Current
snmpwalk -v2c -c public obama 1.3.6.1.2.1.47.1.1.1.1.2 | grep -i "power module current"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.39039503 = STRING: "Power Module Current Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.49413261 = STRING: "Power Module Current Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.53687180 = STRING: "Power Module Current Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.61976104 = STRING: "Power Module Current Sensor"
root@Slack:~# snmpwalk -v2c -c public obama 1.3.6.1.2.1.47.1.1.1.1.7 | grep -i "current 0/pm"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.39039503 = STRING: "current 0/PM3/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.49413261 = STRING: "current 0/PM1/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.53687180 = STRING: "current 0/PM0/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.61976104 = STRING: "current 0/PM4/SP"
snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.39039503
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.39039503 = INTEGER: 7200
snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.49413261
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.49413261 = INTEGER: 7000
Voltage
snmpwalk -v2c -c public obama 1.3.6.1.2.1.47.1.1.1.1.7 | grep -i "voltage 0/pm"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.3355929 = STRING: "voltage 0/PM0/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.11644853 = STRING: "voltage 0/PM4/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.22263542 = STRING: "voltage 0/PM3/SP"
SNMPv2-SMI::mib-2.47.1.1.1.1.7.32635680 = STRING: "voltage 0/PM1/SP"
snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.3355929
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.3355929 = INTEGER: 53805
snmpwalk -v2c -c public obama 1.3.6.1.4.1.9.9.91.1.1.1.1.4.11644853
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.11644853 = INTEGER: 54207
09-15-2011 01:11 AM
i mean not just the community, but that the community belong to the SystemOwner.
so, for example, if i have the community public, the complete command would be:
"snmp-server community public SystemOwner"
having only "snmp-server community public" won't allow us to poll the environmental information.
/A
09-14-2011 05:07 AM
Hi Andreas,
For example:
FAN speed
entPhysicalDescr
entPhysicalName
Geting Fan Speed
Current
Voltage
09-14-2011 05:40 AM
I have already tried this, but i dont get any match when i grep after power module or fan/speed. Is there any difference if the routers are powerd by -48vdc? The fans should still be able to monitor since they are located in the ASR9k Chassis?
XR version is 4.1.0.
/Andreas
09-14-2011 06:15 AM
Hi Andreas,
do you have asr9k-mgbl PIE installed?
do you have 9010 or 9006 chassis?
/A
09-14-2011 11:10 PM
Yes i have the asr9k-mgbl PIE installed. It is a 9006 chassis.
09-14-2011 11:46 PM
Hi Andreas,
Does the community on the ASR has SystemOwner permissions attached to it?
snmp-server community xyz SystemOwner
/A
09-15-2011 01:06 AM
Yes the snmp-server community is configured.
09-15-2011 01:11 AM
/A
09-15-2011 01:23 AM
OK!
Now were talking..
The SystemOwner solved the problem.
Thanx!
06-29-2019 06:35 PM
Hi Alexei,
I'm able to get the power information but not the fan speed with 5.1.3. But I can get it with 5.3.4. I had "snmp-server community public SystemOwner" configured. Do you know the reason?
William
