ASA SSL VPN troubleshooting
Sep 14th, 2011
I am working on an ASA that is running version 8.0 (4). Does this error cause the SSL VPN portal to not show Cisco logo along with not displaying start anyconnect once I login?
float-fw-01(config-webvpn)# enable External
ERROR: entry for address/mask = 0.0.0.0/0.0.0.0 exists
%ERROR: csco_config.lua:36: csco_config.lua:552: copying
'disk0:/csco_config/locale/ja/LC_MESSAGES/customization.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/ja/LC_MESSAGES/PortForwarder.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/ja/LC_MESSAGES/webvpn.po' to a temporary ramfs file
failed
'disk0:/csco_config/locale/fr/LC_MESSAGES/customization.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/fr/LC_MESSAGES/PortForwarder.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/fr/LC_MESSAGES/webvpn.po' to a temporary ramfs file
failed
'disk0:/csco_config/locale/ru/LC_MESSAGES/customization.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/ru/LC_MESSAGES/PortForwarder.po' to a temporary ramfs
file failed
'disk0:/csco_config/locale/ru/LC_MESSAGES/webvpn.po' to a temporary ramfs file
failed
csco_config.lua:7297: copying 'disk0:/csco_config/97/customization/index.ini' to
ramfs file '
cind.ini' failed
INFO: WebVPN and DTLS are enabled on 'External'.
Herbert Baerten Sun, 09/18/2011 - 15:23
  • Cisco Employee,
Hi Esteban,
it looks like you're running into one or two bugs in 8.0(4):
CSCsy77628    the procedure of copying a file from ramfs to flash should be atomic
CSCsq19457    ERROR: entry for address/mask = 0.0.0.0/0.0.0.0 may break webvpn or ASDM
Both are fixed in 8.0(5).
hth
Herbert
