How to configure ASDM on Cisco ASA 5505
Answered Question
Sep 15th, 2011
I have a firewall Cisco ASA 5505, and currently it is a command line firewall. I want to configure ASDM so that i can use it as a GUI Web Base interface.
I really dont know what to do. Can any one please help me how can i configure ASDM on my firewall.
Naushad Khan
Correct Answer by varrao about 5 years 10 months ago
Hi Naushad,
First of all you need to load the ASSDM image on ASA and then use the command:
asdm image dosk0:/asdm645.bin     (if image name is asdm645.bin)
then:
http server enable
http 10.0.0.0 255.0.0.0 inside      (if your machine is in 10.0.0.0 subnet behind inside inetrafce)
Go to the machine, open a browser and type in:
https://
it will open the GUI.
Varun
Please do rate helpful posts.
Overall Rating: 3.3 (8 ratings)
Correct Answer
varrao Thu, 09/15/2011 - 04:22
  • Red, 2250 points or more
Hi Naushad,
then:
http server enable
https://
Varun
naushad_khan Thu, 09/15/2011 - 04:30
Dear Varun,
From where i can download this bin file. And another thing, my Firewall is configured on a production server. Will there be any connectivity fluctuation during this process ?
Naushad Khan.
varrao Thu, 09/15/2011 - 04:41
Hi Naushad,
You would first need to check whihc is the compatible image of of ASDM with your ASA version from here:
http://www.cisco.com/en/US/docs/security/asa/compatibility/asamatrx.html
and then go to this link and download teh image:
http://www.cisco.com/cisco/software/release.html?mdfid=279916854&flowid=4373&softwareid=280775065&release=8.4.2.ED&rellifecycle=&relind=AVAILABLE&reltype=all
Hope this helps.
Varun
naushad_khan Thu, 09/15/2011 - 05:45
Dear Varun,
When i am trying to download the .bin file from the link you have provided, i am getting the following message.
To Download this software, you must have a valid service contract associated to your Cisco.com user ID.
  • If you do not have a service contract you can get one through:
    • Your Cisco Account Team if you have a direct purchase agreement with Cisco
    • Your Cisco Partner or Reseller
  • Once you have the service contract you must associate your service contract to your Cisco.com user ID with Profile Manager
varrao Thu, 09/15/2011 - 06:06
Hi Naushad,
To download any software you need to have a  valid Cisco contract and a CCO ID for it, otherwise you won't be able to do it.
Varun
FalconFour Wed, 05/07/2014 - 10:46
Thanks for that utterly useless response. Glad Cisco cares so much for their customers, they make it impossible to download the software they wave in front of you and tell you that you need. So I'm stuck using this ridiculously asinine command-line interface for a ASA 5505 that seems to have lost its GUI interface (404 error when accessing any page via https including the root), and am unable to download the file needed to repair it.
It probably doesn't matter one bit to you, but thanks to your aloof reply here of "oh, you need to have a service contract" as if that's somehow something to be taken for granted, ensures I'll be recommending against Cisco products any time I see them.
Screwball011 Fri, 05/15/2015 - 14:11
Thanks for helping Varun.  I was able to setup ASDM in a few minutes!  Great posting and support.
Scott
