09-15-2011 10:43 AM - edited 03-16-2019 07:01 AM
I've following call-flow
PSTN --------FXO/3925/CME----CUE AA
I realized at times when PSTN caller presses extension, the CUE keeps on repeating the AA Pilot prompt instead of directing the call to extension number. It's happening intermittently.
I am running the following IOS:
c3900-universalk9-mz.SPA.151-2.T1.bin
I ran "debug VPM signal" and noticed there are duplicate DTMF received on the router and that is when the call fails/goes into AA repetition mode.
I dialled ext 3031 but in the debugs I could see router receiving 30311 on first attempt, 30311 on second and third attempts. After few attempts, it wored on the same call and I could get routed to ext 3031. That made me feel it's not CUE problem.
OUTPUT OF DEBUG VPM SIGNAL:
E_HTSP_PROCEEDING]fxols_offhook_prochtsp_alert_notify
Sep 15 15:54:12.337: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Sep 15 15:54:12.341: htsp_call_bridged invoked
Sep 15 15:54:12.345: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Sep 15 15:54:12.345: [0/0/0] set signal state = 0xC timestamp = 0
Sep 15 15:54:12.345: htsp_timer_stop
Sep 15 15:54:12.345: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Sep 15 15:54:12.661: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
Sep 15 15:54:12.661: htsp_timer_stop2
Sep 15 15:54:15.297: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:15.557: htsp_digit_ready(0/0/0): digit = 0
Sep 15 15:54:15.817: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:15.917: htsp_digit_ready(0/0/0): digit = 1
Sep 15 15:54:16.037: htsp_digit_ready(0/0/0): digit = 1
Sep 15 15:54:22.477: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:22.721: htsp_digit_ready(0/0/0): digit = 0
Sep 15 15:54:22.837: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:22.957: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:23.177: htsp_digit_ready(0/0/0): digit = 1
NHCHC-3925#
Sep 15 15:54:28.557: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:28.801: htsp_digit_ready(0/0/0): digit = 0
Sep 15 15:54:29.037: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:29.117: htsp_digit_ready(0/0/0): digit = 1
Sep 15 15:54:29.257: htsp_digit_ready(0/0/0): digit = 1
NHCHC-3925#
Sep 15 15:54:36.340: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:36.596: htsp_digit_ready(0/0/0): digit = 0
Sep 15 15:54:36.716: htsp_digit_ready(0/0/0): digit = 0
Sep 15 15:54:37.076: htsp_digit_ready(0/0/0): digit = 3
Sep 15 15:54:37.456: htsp_digit_ready(0/0/0): digit = 1
Sep 15 15:54:37.504: htsp_timer_stop3 htsp_setup_req
Sep 15 15:54:37.504: htsp_process_event: [50/0/115.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
Sep 15 15:54:37.504: htsp_ephone_start_caller_id_tx calling
OUTPUT OF SHOW VOICE PORT
NHCHC-3925#sh voice port 0/0/0
Foreign Exchange Office 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is Main-905-523-6611-hunt#1
Noise Regeneration is disabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to -5 dB
Out Attenuation is Set to 4 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar opx
Connection Number is 8001
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for CA
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
The show run of voice-port is as following:
voice-port 0/0/0
trunk-group OUTBOUND 15
input gain -5
output attenuation 4
no vad
no comfort-noise
cptone CA
connection plar opx 8001
description Main-905-523-6611-hunt#1
caller-id enable
Can someone give me pointers to look at?
thanks in advance,
inner_silence
09-15-2011 12:11 PM
Not simple, but you might need a pcm capture to see if we are receiving multiple digits on your FXO lines. I agree, the FXO port / DSPs are definitely seeing multiple presses, but a PCM capture with the logs are the next step. The PCM capture will show you exactly what is coming across the line.
https://supportforums.cisco.com/docs/DOC-14060
Just make sure that you turn this off after have completed the capture. You don't want to crash your router.
11-08-2011 09:06 AM
I provided the PCM captures to TAC and they informed me that the DTMF tones are of poor quality from Telco.
I contacted Telco and they said, it seems they are sending DTMF at very high Decibel level due to which CME thinks it is receiving multiple DTMF digits.
Telco lowered down the DB level on DTMF tones and it resovled the issue.
Appreciate your recommendations.
thanks,
inner_silence
