09-16-2011 06:01 AM - edited 03-16-2019 07:01 AM
hi,
The corlist has been configured on the CME and some users only use last 7 fxo line to call outside .When i put callfwdall to external number on one user ip phone.The call goes to first FXO line but that ip phone configured to use last 7 fxo ports.
when we do cfwdall it is not using the corlist configured .
09-19-2011 06:35 AM
Can we see your config
Alex
09-19-2011 10:19 PM
Pleas find the config below
sh run
Building configuration...
Current configuration : 22492 bytes
! Last configuration change at 15:33:44 AST Thu Feb 24 2011 by admin
! NVRAM config last updated at 15:36:33 AST Thu Feb 24 2011 by admin
version 15.1
service password-encryption
hostname AUH-RTR-01
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.151-1.T.bin
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
enable secret 5 $1$JpVM$AIeN4V1zpClp.PyJAFBnl.
no aaa new-model
clock timezone AST 4
--More-- no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.200.1 192.168.200.20
ip dhcp pool LAN
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
option 150 ip 192.168.200.1
dns-server 213.42.20.20
no ip domain lookup
trunk group FXOPORTS
--More-- hunt-scheme round-robin
voice-card 0
voice service voip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
h225 timeout tcp establish 3
--More-- !
voice class dualtone-detect-params 1
freq-max-deviation 20
cadence-variation 20
voice class custom-cptone UAE-CPTONE
dualtone disconnect
frequency 400 405
cadence 380 380 400 350 225 525
license udi pid CISCO2921/K9 sn FHK1431F15L
hw-module ism 0
hw-module pvdm 0/0
username michaelchalhoub password 7 004651
username didierbrun password 7 004651
--More-- username stevemckenlay password 7 114B5B
username joy password 7 054944
username cherianthomas password 7 08630E
username menon password 7 004651
username josimpson password 7 015144
username stevenimmo password 7 100C4B
username chrismchardy password 7 155049
username nancymathews password 7 004651
username neilcameron password 7 024446
username jairai password 7 041949
username james password 7 134755
username anirban password 7 134755
username clareto password 7 054944
username sreekanth password 7 034619
username admin privilege 15 password 7 094F471A1A0A
username Rajeev password 7 06444D
username Anthony password 7 145550
username Adelle password 7 134755
username ahmadsahtout password 7 024446
username JamesBurton password 7 034619
username MeetingRoom password 7 004651
username MartynThomas password 7 041949
username OmarJuma password 7 090E0C
--More-- !
redundancy
interface GigabitEthernet0/0
ip address 192.168.200.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 192.168.200.10 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 192.168.200.1
interface ISM0/1
no ip address
shutdown
--More-- interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 192.168.0.0 255.255.255.0 192.168.200.254
ip route 192.168.200.10 255.255.255.255 ISM0/0
--More-- tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:DistinctiveRingList.xml
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
--More-- tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:RingList.xml
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:Ring4.raw
tftp-server flash:music-on-hold.au
tftp-server flash:apps11.8-5-3TH1-6.sbn
tftp-server flash:cnu11.8-5-3TH1-6.sbn
tftp-server flash:cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:dsp11.8-5-3TH1-6.sbn
tftp-server flash:jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:SCCP11.8-5-3S.loads
tftp-server flash:term06.default.loads
tftp-server flash:term11.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term45.default.loads
tftp-server flash:SCCP45.8-5-3S.loads
tftp-server flash:jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:dsp45.8-5-3TH1-6.sbn
tftp-server flash:cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:cnu45.8-5-3TH1-6.sbn
tftp-server flash:apps45.8-5-3TH1-6.sbn
control-plane
voice-port 0/1/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CPTONE
supervisory dualtone-detect-params 1
cptone AE
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx 100
caller-id enable
voice-port 0/1/1
cptone AE
--More-- timeouts call-disconnect 1
connection plar opx 101
caller-id enable
voice-port 0/1/2
cptone AE
connection plar opx 102
caller-id enable
voice-port 0/1/3
cptone AE
connection plar opx 105
--More-- caller-id enable
voice-port 0/2/0
trunk-group FXOPORTS
cptone AE
connection plar opx 201
caller-id enable
voice-port 0/2/1
cptone AE
caller-id enable
--More-- !
voice-port 0/2/2
cptone AE
caller-id enable
voice-port 0/2/3
cptone AE
caller-id enable
--More-- voice-port 0/3/0
cptone AE
caller-id enable
voice-port 0/3/1
cptone AE
caller-id enable
voice-port 0/3/2
--More-- trunk-group FXOPORTS
cptone AE
caller-id enable
voice-port 0/3/3
cptone AE
caller-id enable
--More-- dial-peer cor custom
name local
name national
name international
name line1
name line2
name line3
name line4
dial-peer cor list local
member local
dial-peer cor list national
member national
dial-peer cor list international
member international
dial-peer cor list LOCALACCESS
member local
dial-peer cor list NATIONALACCESS
--More-- member local
member national
dial-peer cor list INTERNATIONALACCESS
member local
member national
dial-peer cor list line1
member line1
dial-peer cor list line2
member line2
dial-peer cor list line3
member line3
dial-peer cor list line4
member line4
dial-peer voice 201 pots
trunkgroup FXOPORTS
--More-- corlist outgoing LOCALACCESS
destination-pattern 9[1-5,7,9]......$
dial-peer voice 202 pots
trunkgroup FXOPORTS
destination-pattern 9[19]..$
dial-peer voice 203 pots
trunkgroup FXOPORTS
destination-pattern 9800T
prefix 800
dial-peer voice 204 pots
trunkgroup FXOPORTS
corlist outgoing INTERNATIONALACCESS
destination-pattern 900T
prefix 00
dial-peer voice 205 pots
trunkgroup FXOPORTS
corlist outgoing NATIONALACCESS
--More-- destination-pattern 905[056].......$
prefix 05
dial-peer voice 206 pots
trunkgroup FXOPORTS
destination-pattern 90[1-4,6-9].......$
prefix 0
dial-peer voice 207 pots
trunkgroup FXOPORTS
destination-pattern 96[0-9][1-9]....$
prefix 6
dial-peer voice 208 pots
trunkgroup FXOPORTS
destination-pattern 98[0-9][1-9]....$
prefix 8
dial-peer voice 209 pots
trunkgroup FXOPORTS
--More-- corlist outgoing NATIONALACCESS
destination-pattern 9600T
prefix 600
dial-peer voice 200 voip
destination-pattern 200
session protocol sipv2
session target ipv4:192.168.200.10
dtmf-relay h245-alphanumeric
codec g711ulaw
dial-peer voice 301 pots
corlist outgoing line1
port 0/1/0
dial-peer voice 302 pots
port 0/1/0
dial-peer voice 303 pots
--More-- destination-pattern 9800T
port 0/1/0
prefix 800
dial-peer voice 304 pots
port 0/1/0
prefix 00
dial-peer voice 305 pots
port 0/1/0
prefix 05
dial-peer voice 306 pots
port 0/1/0
prefix 0
dial-peer voice 307 pots
--More-- corlist outgoing line1
port 0/1/0
prefix 6
dial-peer voice 308 pots
port 0/1/0
prefix 8
dial-peer voice 309 pots
port 0/1/0
prefix 600
dial-peer voice 401 pots
corlist outgoing line2
port 0/1/1
dial-peer voice 402 pots
--More-- corlist outgoing line2
port 0/1/1
dial-peer voice 403 pots
port 0/1/1
prefix 800
dial-peer voice 404 pots
port 0/1/1
prefix 00
dial-peer voice 405 pots
port 0/1/1
prefix 05
dial-peer voice 406 pots
port 0/1/1
prefix 0
dial-peer voice 407 pots
port 0/1/1
prefix 6
dial-peer voice 408 pots
port 0/1/1
prefix 8
dial-peer voice 409 pots
port 0/1/1
prefix 600
--More-- dial-peer voice 501 pots
corlist outgoing line3
port 0/1/2
dial-peer voice 502 pots
port 0/1/2
dial-peer voice 503 pots
port 0/1/2
prefix 800
dial-peer voice 504 pots
port 0/1/2
prefix 00
dial-peer voice 505 pots
--More-- corlist outgoing line3
port 0/1/2
prefix 05
dial-peer voice 506 pots
port 0/1/2
prefix 0
dial-peer voice 507 pots
port 0/1/2
prefix 6
dial-peer voice 508 pots
port 0/1/2
prefix 8
--More-- dial-peer voice 509 pots
port 0/1/2
prefix 600
dial-peer voice 601 pots
corlist outgoing line4
port 0/1/3
dial-peer voice 602 pots
port 0/1/3
dial-peer voice 603 pots
port 0/1/3
prefix 800
dial-peer voice 604 pots
--More-- corlist outgoing line4
port 0/1/3
prefix 00
dial-peer voice 605 pots
port 0/1/3
prefix 05
dial-peer voice 606 pots
port 0/1/3
prefix 0
dial-peer voice 607 pots
port 0/1/3
prefix 6
--More-- dial-peer voice 608 pots
port 0/1/3
prefix 8
dial-peer voice 609 pots
port 0/1/3
prefix 600
dial-peer voice 300 voip
destination-pattern 201
dtmf-relay sip-notify
codec g711ulaw
no vad
--More-- gatekeeper
shutdown
telephony-service
authentication credential admin gbm4ibm*
max-ephones 42
max-dn 100
ip source-address 192.168.200.1 port 2000
timeouts interdigit 2
system message Your Current Options
url services http://192.168.200.10/voiceview/common/login.do
url authentication http://192.168.200.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7911 SCCP11.8-5-3S
load 7965 SCCP45.8-5-3S
time-zone 35
date-format dd-mm-yy
voicemail 200
max-conferences 10 gain -6
call-forward pattern .T
moh flash:music-on-hold.au
--More-- web admin system name admin secret 5 $1$3ipn$19NT2sz9pDa1guAWxspjS/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
softkeys hold Resume Newcall Select Join
softkeys idle Redial Newcall Cfwdall Gpickup Login
softkeys seized Redial Endcall
softkeys alerting Endcall
softkeys connected Hold Endcall Trnsfer Confrn ConfList Select Join
softkeys ringing Answer
ephone-dn 1 dual-line
number 100
pickup-group 1
label Michael Chalhoub x100
name Michael Chalhoub
--More-- call-forward busy 200
call-forward noan 200 timeout 20
corlist incoming line1
ephone-dn 2 dual-line
number 101
pickup-group 1
label Didier Brun x101
name Didier Brun
corlist incoming line2
ephone-dn 3 dual-line
number 103
pickup-group 1
label Joy Chakravarty x103
name Joy Chakravarty
corlist incoming INTERNATIONALACCESS
--More-- !
ephone-dn 4 dual-line
number 104
pickup-group 1
label Cherian Thomas x104
name Cherian Thomas
ephone-dn 5 dual-line
number 105
pickup-group 1
label Omar Juma x105
name Omar Juma
corlist incoming line4
ephone-dn 6 dual-line
--More-- number 106
pickup-group 1
label Jo Simpson x106
name Jo Simpson
ephone-dn 7 dual-line
number 107
pickup-group 1
label Steve Nimmo x107
name Steve Nimmo
ephone-dn 8 dual-line
number 108
pickup-group 1
label Chris McHardy x108
--More-- name Chris McHardy
ephone-dn 9 dual-line
number 109
pickup-group 1
label Nancy Mathews x109
name Nancy Mathews
ephone-dn 10 dual-line
number 110
pickup-group 1
label Ahmad Sahtout x110
name Ahmad Sahtout
--More-- corlist incoming INTERNATIONALACCESS
ephone-dn 11 dual-line
number 111
pickup-group 1
label Jai Rai x111
name Jai Rai
ephone-dn 12 dual-line
number 112
pickup-group 1
label James Piercy x112
name James Piercy
--More-- ephone-dn 13 dual-line
number 113
pickup-group 1
label James Burton x113
name James Burton
call-forward noan 200 timeout 10
ephone-dn 14 dual-line
number 114
pickup-group 1
label Clareto Monsorate x114
name Clareto Monsorate
ephone-dn 15 dual-line
number 115
pickup-group 1
--More-- label Sreekanth Kariatath x115
name Sreekanth Kariatath
ephone-dn 16
number 116
pickup-group 1
label Rajeev Karunan x116
name Rajeev Karunan
corlist incoming NATIONALACCESS
ephone-dn 17
number 117
pickup-group 1
label Adam Flinter x117
name Adam Flinter
--More-- call-forward noan 200 timeout 20
hold-alert 30 originator
ephone-dn 18
number 118
pickup-group 1
label Anthony Fernandes x118
name Anthony Fernandes
ephone-dn 19
number 119
pickup-group 1
label Adelle Hermogenes x119
name Adelle Hermogenes
ephone-dn 20
number 120
pickup-group 1
label Meeting Room x120
description Meeting Room
name Meeting Room
ephone-dn 21 dual-line
number 121
pickup-group 1
label Suzanne x121
name Suzanne Filio
ephone-dn 22
number 122
label Martyn Thomas x122
name Martyn Thomas
ephone-dn 25 dual-line
number 102
pickup-group 1
label Steve McKenlay x102
name Steve McKenlay
corlist incoming line3
--More-- ephone-dn 48
number 801...
mwi on
ephone-dn 49
number 802...
mwi off
ephone 1
mac-address 1C17.D341.CA47
ephone-template 1
max-calls-per-button 2
type 7965
button 1:1
ephone 2
mac-address A40C.C395.0EB7
ephone-template 1
--More-- type 7965
button 1:2
ephone 3
mac-address DC7B.9476.DA89
ephone-template 1
type 7911
button 1:3
ephone 4
mac-address DC7B.9477.5CA4
ephone-template 1
type 7911
button 1:4
--More-- ephone 5
mac-address D057.4CF7.FFD9
ephone-template 1
type 7911
button 1:5
ephone 6
mac-address DC7B.9477.7A94
ephone-template 1
type 7911
button 1:6
ephone 7
mac-address D057.4CF7.FD70
ephone-template 1
type 7911
--More-- button 1:7
ephone 8
mac-address D057.4CF7.F742
ephone-template 1
type 7911
button 1:8
ephone 9
mac-address DC7B.9477.7BC8
ephone-template 1
type 7911
button 1:9
ephone 10
--More-- mac-address DC7B.9477.7934
ephone-template 1
type 7911
button 1:10
ephone 11
mac-address D057.4CF7.FF23
ephone-template 1
type 7911
button 1:11
ephone 12
mac-address DC7B.9477.64D7
ephone-template 1
type 7911
button 1:12
--More-- !
ephone 13
mac-address D057.4CF7.FAC0
ephone-template 1
type 7911
button 1:13
ephone 14
mac-address DC7B.9477.7B3B
ephone-template 1
type 7911
button 1:14
ephone 15
mac-address D057.4CF7.FCB3
--More-- ephone-template 1
type 7911
button 1:15
ephone 17
mac-address 68BD.ABA5.21A5
type 7911
button 1:16
ephone 18
mac-address DC7B.94F9.0D8F
type 7911
button 1:17
ephone 19
mac-address DC7B.94F9.A497
--More-- type 7911
button 1:18
ephone 20
mac-address DC7B.94F9.0D1E
type 7911
button 1:19
ephone 21
mac-address DC7B.94F9.0D62
type 7911
button 1:22
ephone 22
mac-address DC7B.94F9.1055
type 7911
button 1:21
--More-- !
ephone 23
mac-address E804.62EB.B26E
type 7965
button 1:20
ephone 25
mac-address D057.4CF7.FAC1
ephone-template 1
type 7911
button 1:25
ephone-hunt 1 peer
pilot 199
list 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115
max-timeout 13
--More-- !
line con 0
password 7 094B4C044D0C151F41
logging synchronous
login local
line aux 0
password 7 011404090F0204026B
login local
line 131
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 151509015023292962
login local
transport input all
line vty 5 15
login local
--More-- transport input all
scheduler allocate 20000 1000
ntp master 1
end
AUH-RTR-01#
09-20-2011 02:51 AM
Looking the config I have picked on just one phone for testing
ephone-dn 22
number 122
name Martyn Thomas
PLEASE ADD THIS:_
ephone-dn 22
Then retest the call fowarding.
If this is answer you want then apply the new line of config to all the affected ephone-dn
Alex
